Old 06-29-2012, 12:17 AM
Default Egmont Key next week
I know it's going to be insane next week, but I have to get my new to me 79 Sceptre broken in! Who is Interested?
Old 06-29-2012, 12:56 AM
doodlebug doodlebug is offline
We will be around Anclote on the 4th, chasing grouper weather permitting and hanging out at my buddies houseboat.
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET
Old 06-29-2012, 04:23 PM
Danny, what does the new boat look like?
Old 06-29-2012, 08:35 PM
Duane-
I just figured out the new forum picture process! Take a look in the photo section. I need to make the size bigger on the pics
Old 06-29-2012, 09:44 PM
Duane-
Your squids are having a great spring. Tall corn indeed. Very nice
Cheers,
US
Old 06-30-2012, 08:13 AM
It has been awhile since our southern crew has convened..
We need to throw something together!!
Enjoy the new ride Danny.. wish we could make the trip and join you.
Old 06-30-2012, 04:18 PM
We're due for an Egmont run now that the weather settled
Anclote tomorrow - Susan's dying to see how the storm moved the sand around
Old 06-30-2012, 04:46 PM
Dixon-That sounds good! I'm getting nowhere on my elec issue
Old 06-30-2012, 05:04 PM
I hate electric - wouldn't know an OHM if it bit me on the ankle - I will say though get a 12V tester with the ice pick end $5 - make a wire long enough to go from a known good ground like the battery even and you can trace down power easy. Only works on little stuff but very helpful, I even carry one on the boat for bilge pump, bait pump or light issues, saves a day sometimes.
re- read your post above, I hate to bring this up but - based on that boat, there might some connection between the helm and the motor its a long run. I would go get that tester though, you could find out if power is getting anywhere back there - start at the front at the key and switch, try and follow the power back - you will lose it somewhere and it then will be in between. Sure helps narrow the search down. Might even be a bad key switch, thats why I said start the front.
Isolate and Eliminate
Old 07-06-2012, 07:44 AM
One idea that was said is that there is a relay in the shifter when put in neutral or just shifting gears that may be killing it?
