Old 08-15-2012, 03:08 PM
Default Torsion axle advice
Cheapazz Chinese springs are toast after one year.
Going torsion.
Advice on brands or tips welcome.
Thx,
GFS
Old 08-15-2012, 03:54 PM
hugo hugo is offline
springs are ok, in the past i have bought a tub of cheap grease and completly coated new springs before ever going in water and had them last 4-5 years easy with no reapplication of grease befor getting rid of the baot and trailer and they were still in great shape. any painted steel spring is going to fail fast is salt water applications.
Old 08-15-2012, 04:02 PM
cdavisdb cdavisdb is offline
I have Dexter's on mine. Owen's Trailers uses them, which is a pretty good recommendation. I just replaced both of mine as one was failing after 12 years, spindle was no longer straight and the tire was wearing crooked. The performance was great, but I had hoped for a little longer life.
Old 08-15-2012, 08:10 PM
The only way to go if your putting trailer in the water in my opinion. I've owned a boat continuosly now since 1975. Three boats on three Float-on trailers in that time. My current trailer is 19 years old now and I replaced the axles about 4 years ago. I think the current axles are Dexter. Float-on used to make their own, but now buy them for their trailers. So far so good on the new ones. If you are running tandem, it helps to have the trailer level(no spring equalizers)
Old 08-15-2012, 10:44 PM
Thanks for the replies.
It seems Dexter and Tie Down are the main players. T D have screw in spindles, but their rep for brakes sucks. If Owens and Float On use Dexters, that says something. I understand the old hot dip chemicals have been gutted by the EPA.
Always learning.
Thanks,
GFS
Old 08-16-2012, 07:46 AM
"T D have screw in spindles, but their rep for brakes sucks"
That's not true, they work great from your house to the boat ramp!! After the first dip in saltwater it's all over, at they moment they are officially a POS.
Old 08-16-2012, 09:19 AM
We"ve done some work on MYCO trailers in the past. I can't recall what type of axles they use, though. You might call them and see if you can get any suggestions. They"re the ones that make the custom trailers for the military and alot of race boats. (High end trailers).
