Old 10-01-2012, 09:42 AM
Default Wire to Console Batteries Advice
I'm thinking 2 gauge would probably be adequate if I run wires to a console battery, shouldn't be more than a ten foot run (20' round trip) if I do it going through the rigging tunnel. Is there any advantage to not running through the tunnel, chance of interference of some sort? I have the chance to run cables under the deck right now since the deck is completely off. That would add at least six feet to the round trip equation however in order to get the cables all the way to the rear corner box.
Old 10-01-2012, 01:35 PM
go to genuinedealz.com and use their calculator for gauge size and then have them make your cables. They do very good work, great prices and free shipping.
Old 10-01-2012, 03:45 PM
Ditto!!
How about a second tube for just battery cables?
Old 10-02-2012, 10:42 AM
dandub20 dandub20 is offline
my boat also currently has no floor, i was thinking about glueing or glassing a 1 1/2 inch pvc on the inside of each foam stringer so i can pull the wires thru when the time comes
Old 10-02-2012, 05:53 PM
If 2" pvc will fit, go bigger!!
Old 10-02-2012, 07:58 PM
Ditto. and bigger than 2" if you can. You'll be shocked how fast a 2" rigging tube will fill up. I've got 3-2" conduits from the engine compartment in my 25. Two go to the helm, the other goes to the battery box. They're all pretty full.
Dave
Blue Heron Boat Works
Old 10-02-2012, 02:13 PM
Ditto!!
that would be my choice, since you can
Old 10-05-2012, 10:57 PM
just a thought most pvc pipe is sch 40 if you get into the "sprinkler "pipe you can get sch20 that gives you a lil more room inside--thinner wall but the same od
