Old 11-28-2012, 07:30 PM
Hooligan Hooligan is offline
Default v6 Inboard on a 23' GM 4.3 200-235 hp?
Interested to know if anyone has any experience with the gm 4.3 vortec inboard/outboard and whether or not it would be an acceptable fit in a 23' CC.
I am considering the original mercruiser 888 from the factory and comparing the 188 hp to the 235 hp numbers of the vortec v6 and considering some weight savings... torque figures may be off from one to the other but no published specs for either.
Do you think performance would suffer with a 4.3 v6?
All thoughts appreciated.
Old 11-28-2012, 09:20 PM
For a Hooligan , you sure don`t get out much. ?# of posts?
I think you know the answer. It may be fine in a 20 class.
Old 11-28-2012, 10:50 PM
What's important in a boat engine is not peak hp that you'll seldom use, it's how much it puts out at the cruise/max continuous rating (at about 5"Hg manifold vacuum) and how much mid-range torque it puts out for climbing on plane. There is typically no substitute for cubic inches for that purpose. I'd pick a 350 ci V-8 over that 4.3L V-6 in a heartbeat. The 4.3L might be ok in a 20, but not a 23, which is a MUCH bigger and heavier boat. A V-8 will also be a much smoother running engine than that 90 degree V-6 which is not a naturally balanced engine like an I-6 or V-8.
A good friend of mine owned a Moesly 21 for 27 years and was on his 4th engine when he sold it. (The SeaCraft 21 is similar in beam and deadrise but lighter than the 23, with better ride and performance.) He was a gung-ho diver and ran it year round every weekend drift diving off Palm Beach carrying 4 divers + gear, and 8 tanks. It came new with a 150 hp I-6 Mercruiser with marginal performance; cruise with that heavy load was about 18 mph @ 5" vacuum. He burned out exhaust valves and cylinder heads often until he learned the importance of observing the 5" vacuum limit. He replaced it with a 165 hp I-6 Mercruiser which picked up cruise speed 1-2 mph. The next engine was a 260 hp Mercruiser V-8 that would easily cruise at 22-23 mph at about 9" vacuum, with much better life on the exhaust valves and seats. His last engine was another 350 chevy, but a Volvo I/O version rated at 290 hp and it was his favorite of the bunch, with a WOT speed of about 50 mph!
Old 11-29-2012, 12:34 AM
The wonderful mind makes many good points here. Spin and burn or loaf and be smart.
Your choice,
GFS
Old 11-29-2012, 08:54 AM
cdavisdb cdavisdb is offline
When it gets rough, the lack of torque in the v6 will make you crazy, jumping on and off plane trying to keep a reasonable speed.
Old 11-29-2012, 10:16 AM
bigeasy1 bigeasy1 is offline
Bushwacker as always,gave great advice.
You won't be happy with the 4.3.I have a 23 Tsunami with a 350 5.7 GM/Mercruiser and Alpha drive,and even with that it's not a rocket ship at top speed.
It does however,hop up on plane almost instantly.and runs effortlessly at cruise speed.I've had a few similar size boats with the smaller,305 GM engines,and they were much slower out of the hole,and were harder to keep speed in nasty water conditions.
I'm probably around 260-270hp on my 350 and am spinning a 15-1/2x17 Mirage SS prop.This combo seems to work the best for me.The 350 definitely has the torque needed to move this boat in all situations,and doesn't have to work as hard as lesser cubic inch engines.
Somewhere,I have my performance numbers written down,but I'm around 36-38 mph at wot,and in the neighborhood of around 25-27 mph at 3000-3200 rpms.
Actually,I'd like even more HP,but at the time I did the restore,I was able to get a bargain on the 350.
Had money not been an issue I would have gone with a 383 stroker,or maybe even a 454.I may be mistaken but I think Water Rat,Chris Downey runs a 454 in his 23.
I'd like to see what his performance numbers are.
All this,just for a boat ride
Old 12-01-2012, 10:56 AM
ScottM ScottM is offline
Dieter Sprockets
I'm sure Chris will chime in, but I don't think his performance with the big block is that much better than a small block. He's got it hitched to a Bravo drive and needs massive Kiekhafer trim tabs to keep her balanced. The biggest down side I've personally witnessed in his boat, and I'm sure he'll concur, is water through the scuppers due to that extra weight. With a couple guys in the back at rest, you've got a good 1" of seawater on deck. Typically I concur with "there's no substitute for cubic inches", but in the case of a 23, it seems to work against you.
The 350 just seems made for the 23; go for that and you'll be more than happy.
Old 12-01-2012, 12:35 PM
Originally Posted by ScottM View Post
. . . Typically I concur with "there's no substitute for cubic inches", but in the case of a 23, it seems to work against you.
It's definitely possible to have too much of a good thing! One friend of ours made the Abaco's trip with me and the "Unohu" in the late 70's in a 23 Sceptre with a 454/No. 2 Mercruiser drive, which was quite heavy because it required a marine transmission between engine and drive. He ran out of gas (with 100 gallon tank) before we got to Cooperstown, a distance of about 130-140 miles! We were headed to Guana Key that year, a distance of about 180 miles, and he was the only boat that couldn't make it non-stop. (I was carrying 80 gallons of gas in the Seafari, over half of it in jugs!) I averaged about 2.8 mpg with the 115 Evinrude and Bob got about 2.5 mpg with the 260 hp/350 Mercruiser in the Moesly 21.
Old 12-03-2012, 10:06 AM
Yeah, I love the 350 and no doubt that the extra weight of a 454 would be a factor with the thru-deck scuppers(I hate them).
I have that problem with the extra weight from the Yamaha kicker(105 lbs),and the four down riggers,each with 15lb weights,two off the stern,and two off the rear sides.
They drain fine when we are sitting forward or amidships,but if we have two of us standing in the rear,as when fighting and netting a fish,water pours in through them.It's not bad on a hot summer day,but in the spring with water temps in the high 30's forget about wearing sneakers.
I made a version of the "Vortex" out of some 2" long pieces of type m copper tube and the finger from a latex glove.Most of the time they work pretty well."most of the time"not all the time.
Old 11-29-2012, 11:30 AM
ct9amr ct9amr is offline
Coming from Shamrocks I would not recommend the 4.3 as an inboard in 23ft.
You definitely need the TQ of a V8 like it has already been stated.
If your doing the V6 for economy its probably not going to work well either since you will be pushing the engine hard.
Glen
