I manage multi-million dollar construction projects, but I'm scratching my head thinking about how a bait well should be set up.
Here is what I think is right or common.....high-speed thru hull pick-up --> seacock --> hose --> pump (such as bait sentry) --> hose --> bait well. I think maybe a strainer should go in there somewhere too? So here is the question: First of all, correct or comment on my "set-up." Second, what I don't understand is what happens under each condition....when running, water gets forced up the pick-up, is the pump running too? If not, does the water just flow thru the pump? When at rest, the pump runs, water goes into the well. If the pump is not running while at rest, does the water not flow back out of the intake line? Hep me! |
That's what I have on my 23'. Add: backing block under seacock for proper mounting, bait well feed is at top of tank. I have no strainer. For menhaden the pump stays on.
At cruising speed, your "scoop" will force more water into the baitwell than the pump could ever "pump" while turned on. Simply turn the pump "off" while running and back "on" when you are fishing.
The Idiot Who Re-Built the Burnt-Up 35 Duffy |
and DOUBLE CLAMP all hoses! or it could be your last trip!
If you are going to use a Bait Sentry, you probably do not need a strainer. They chew up debris really well due to their design. They also last a LOT longer than the cheaper pumps. I had one for three years before I sold that boat without issues. The thing I do not like about them is they are pretty noisy.
When at rest with the pump off, water will flow out the inflow and will seek the level of the water line. So, if the tank is above deck, it will drain completely if the inlet is at the bottom of the tank. I always keep mine on because I would often forget to turn it back on when I stop. Some use the ball valve to restrict flow of water while under way also. |
I have high scoop pick up over a through hull, through hull goes into a backing plate, bait sentry pump screws right into top of through hull.
The large thru-hull you can see in this picture is a large drain, the small one in front if the baitwell pick up before putting on the pump. All are Marleon made by Forespare, super strong, no corrosion, no electrolysis http://gallery.bateau2.com/albums/us..._shine_667.jpg ![]()
http://www.boatbuildercentral.com/ ![]() my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=22090 |
I like your set up, except I would go clam shell thru-hull, seacock, to a rhule pump that screws right into the seacock. I use mine in a year more than most do in 3, also if the pump goes, you are only changing out the cartridge at the top of the pump. I have not needed a sea strainer as the clamshell seems to keep most of the crap out.
I leave my pump on all the time, when you are running things are charging anyways. Those rule pumps don't draw much either. If you shut off when you run, and forget to turn it back on you might be up for a big disappointment when you look in your livewell. The delivery method for the water is important based on what type of bait you are trying to keep alive. |
