The bronze thru hull transducer by Lowrance is tilted to accomodate the angle of the bottom of the hull. Does 20 degrees sound like the correct angle? I believe it comes in 12 or 20 degrees. Thank you.
I've got the 20 degree Airmar B-164. Works perfect. I think they are all made by Airmar, mine has a plug to fit Raymarine products, your model will have a plug to fit your brand.
http://www.airmartechnology.com/2009...id=37&manf=All |
Go with the 20 degree transducer. it is designed for hulls with deadrise from 16 to 24 degrees. With 20 degrees at the transom, the 23 fits perfectly in that range.
Buzzcutt
Experience: The ability to recognize a mistake when you make it again. If you can't fix it with a hammer, you have an electrical problem. |
Thank you for the information-as this 23 gets put back into service I am sure more questions will emerge/ Thanks again.
