Old 06-01-2013, 09:52 AM
Default Bracket modification
I am going to really eat my word now, This is an old Dusky bracket that I am going to "chop up" and modify to fit my 20 sceptre. It is way to tall and has a splash well built in. I plan on cutting it down to 24" high or so and getting rid of the splash well and building a swim platform to go all the way across the back of the boat. I originally has two small bolt on swim platforms (20"x20") on each side of the bracket, but I don't think I will use them. It weighs a ton but once I cut it down it should not be as bad. It is well built with almost 4" thick of glass/wood on the flotation tub. I got it for really cheep so I figured it was worth a try, I cant afford a new Hemco but would like one. I will see how it turns out, maybe it will be usable and not look so bad once completed. It will defiantly have a ton of flotation to help with the weight of it and the new motor.
Old 06-01-2013, 07:15 PM
Tiny Tiny is offline
Wow that is one boss of a bracket there...used to own one of their 21 ft inboards...built like a tank for sure. I don't know if you could ever cut enough off to lighten up a bracket built that solid :-). I know things are tight man, but there are 5 boats in your sig...maybe sacrifice one for some $ to build out another....
Old 06-02-2013, 06:15 AM
Might want to also check and see if the transom angle is the same for some reason I seem to remember they are not the same.was looking at getting one from dusky before finding a stainless marine one for mine.have to say the guys at dusky were great to work with a family run business that cares for there customers
Old 06-02-2013, 08:13 AM
The angle will work just fine, checked that out before I got it. The sceptre has a angle of 13 degrees (some say 14 some say 13 mine measures 13). The dusky bracket has an angle of 12 degrees, more like 12.25 degrees so it will be close enough to use. The less than one degree will just let the swim platform have a slight angle down towards the motor. So small you wont notice and it will help the water run off the transom. I have read you can use a bracket at + or - a degree with no worries.
Old 06-02-2013, 08:56 PM
Good to hear that ! Glad it worked out
Old 06-02-2013, 10:19 PM
It hasent worked out yet, angle looks good and it seems to look like it will fit fine but it is mighty heavy. The tub is two inches thick with two 5/8 layers of glass with a 3/4 wood core between them. Took a lot of weight off by getting rid of the splash well and cutting it down but hopeing that the large flotation space will make up for the extra weight.
Old 06-02-2013, 08:05 AM
I have removed about a 1/3 of the weight off her but it is still weighing in a little heavy at 130-140lbs. I wouldn't put on a cc but with the weight forward on the sceptre and I think the weight will be less than the old I/o unit so im not to worried.
Far as selling the other projects there is not much value there, all were like orphan children and were about given to me at very low $ amounts. I am trying to do what you were saying thoe. Out of my 15 or so boats I actually got 5-6 boats up for sale right now (none of them SeaCrafts of course).
I wont be as cheep on the others SC projects. The sceptre was to be a low budget build used just solely for the purpose of pulling the kids on tubes and hydro-slides. I was trying to get it going and have less than $3000 in it total including motor.
The race boat will be started soon and I don't want to spare a dime on it. Just wanted some cheep fun for the kids with this one.
If the bracket don't work out I will loosen my cheeks, buy a sheet of 6061 aluminum and build one myself, (Have welding equipment and my father builds tops and towers for a living and can professionally do it) I just hate to spend the $1000 for a 4x8 sheet!
Old 06-05-2013, 09:25 PM
If you want a bracket, I wouldn't suggest 6061. You won't be re heat treating it after welding, so the welds will be quite weak compared to the rest of the sheet. Use 5086 instead with much higher "as welded" yield and ultimate strength, and it will have better corrosion resistance, too. Make sure you use the right filler rod. I think it is 5183.
If you were closer, I would say buy my bracket made of 5086. I think it is 125 lb with platform.
Old 06-06-2013, 07:01 AM
You got a good point there about the heat treating, Im not sure what grade would be best but I will be looking into it and doing some research before buying a sheet when I get ready to do the bracket for the race boat. I will check on the 5086 and see if that will be best. I know I want something strong and know that some of the high grade aluminum will work better than others, thanks for the help. I need to study up on it a little better so I go the right direction.
Old 09-10-2013, 07:25 AM
would a 20 inch shaft be better on a bracket on these ???? looking at several installations it seems a 20 " motor would make the adjustments easier and not have to redrill holes to raise the motors ???
RUSTY PARKER
