well got started on the tear down this weekend, got her disassembled and ready to pull the cap, every thing came apart fairly easy ill I got to the fuel tank, then I found the Potter foam!!!
I got My fiberglass guy coming over tomorrow to give her a look and some ideas on what is to come. I know he time to start spending $ is in My near future!!!
1973 20' seafari ob "old Yeller" sold 1972 25' seafari W/ 150 mercs {under renovation} |
Good luck with your '73...... I am hoping to get some more tore down on my '73 also this next week.
Foam helps hold water against the tank to cause the equivalent of crevice corrosion, so might as well plan on replacing that tank! Use a pressure washer to blow away all that foam and remove the tank! And DON'T foam in the new tank!
ran into that with my 25, tanks were shot, had to have new tanks custom built for it.
ill go back with a poly tank on this one I did get the console stripped down today, is in kinda rough shape, gonna take some work to fix all the cracks in it .
Ok, been a while since I posted anything, put the 20 on the back burner for a while,{deer season in Ga is 4 months long
few more with the transom bout removed
deck off , all rotten wood removed, tank and foam removed, almost time to start construction instead of destruction!!!!
Im trying to do this with out removing the front liner, anyone else done it this way?
You asked about getting the foam out. Well, for getting every last bit, I would suggest:
I would pull the tank deck/floor, then pressure wash. Then pressure wash with soap, like simple green to degrease. Then pressure wash with clean water. Then grit blast anywhere you want to glass or paint, then pressure wash with clean water again. Then you are cleaned, and you don't need to sand. |
How about the foam in the stringers, mine was saturated with water. I ended up cutting the tops off of the stringers and removing all of the foam. It was a real mess but I just couldn't see leaving wet foam in there.
the foam in the stringers is dry, I stuck My moisture meter I use for My house plants into it and it came up dry!. the foam around the gas tank was the only foam that was wet
