Old 12-04-2014, 05:58 PM
Default T-Top Skins
My boat still has the original fabric t-top cover from when bought new in 2001. Lots of small holes starting to develop. Could probably get another season out of it but I'm considering converting to a thin, lighweight hardtop "skin". Does anyone have any experience with these or suggestions for who makes them? I'm leery about going to a standard fiberglass top because of weight considerations on a 21' boat. Thanks
Old 12-04-2014, 07:55 PM
Most are built custom. You might also have to modify the t top to make it where it will bolt on right but not a issue just additional cost. I am worried about weight big time on my 25' seafari and want a hard top. I am building mine out of biaxial carbon fiber with corecell or similar foam as a core. I figured that I can do one at about a 1/3 of a standard fiberglass wood core type. Carbon cost a lot but you can find it on close outs online for cheaper than some s-glass. With the way the deep vee on the 25' is weight is a serious issue but your boat should handle it better.
Old 12-04-2014, 08:18 PM
I'm considering converting to a thin, lightweight hardtop "skin"...
So, from your description, I'm seeing a thin laminate in lieu of canvas. I've never seen what you're describing, but the idea is intriguing.
You could take the canvas off your T-top and use it as a pattern to lay up a couple layers of 1808 with gelcoat on the top side and then drill holes in the same locations as the canvas, add grommets just like the canvas, and install it with nylon line, just like the canvas. It should be durable as long as there aren't any hard points that it would be stretched over, and it would be really simple to make. Is that what you're thinking?
Blue Heron Boat Works
Old 12-04-2014, 09:10 PM
No, actually I was thinking of a very thin hard top which would be adhered to the tower permanently not using the nylon line & grommets. I realize this would have to be custom made and I've seen some boats with these tops- just looking for someone in NJ area to consult with and get an estimate- don't know who does this kind of thing.
Old 12-05-2014, 09:26 AM
So you would eliminate the present T-top "outer frame" and not do as Dave mentioned, substitute a thin solid top in place of the canvas? To custom make a solid T-top which would
mount on the legs of your present structure is going to be quite the project.
Google "T-top pictures", there is a lot to look at for ideas.
Old 12-05-2014, 11:58 AM
dave s dave s is offline
Alumapole company used to make a plastic material called Pro-Trim, to replace the ttop canvas; much more durable and lightweight.
They also made hats and fly line buckets out of the stuff.
Probably similar materials out there.
Easier than molding a top out of glass and foam.
Old 12-05-2014, 05:04 PM
bigeasy1 bigeasy1 is offline
Ditto to the above.
Our company deals with Alumapole products.We're in the scaffold rental and sales business,and we rent out the aluma pole systems.We don't deal with the marine stuff,but I remember one of our previous workers had used it on his Ctr console and liked it better than canvas.I never saw the boat,but he was very happy with it for the top.
Here's the marine side of their company.
http://www.alumapole.com/alumarinemain.html
All this,just for a boat ride
Old 12-12-2014, 11:51 PM
martin martin is offline
I can make you one ..it is really simple
Old 01-04-2015, 06:45 PM
kneedeep kneedeep is offline
this is what I did to mine. layed up with gelcoat ,mat/1708 only. i may go later and add 1/2'' nidacore to it. so far so good.http://s728.photobucket.com/user/88b...o%20hard%20top
Old 12-06-2014, 06:23 PM
htillman htillman is offline
Topsntowers in tx offered an alternative to canvas as an upgrade. It appeared to be a marine grade starbrite material. No more than a 1/4" thick, pretty flexible. Secured it by through bolting to the bow.
