So I'm going through a full restoration on a 1975 20 CC. I just realized the shop forgot to add a transom drain plug. I need to drill a new one and was wondering if anyone has done this before and has recommendations on how to handle it. size, fitting, location etc.
Drill it at least 1/4" larger then back fill it with thicken resin then re drill it the correct size. This will give you a good sealed hole.
Same idea different twist--I also drilled oversized and used resin to set in a PC of a old fiberglass outrigger tube I had laying around
My Transom is poured do I still need to resin it?
I wouldn't think so. another advantage of a poured transom.
I installed a garboard drain plug assembly thru the bottom of the keel versus out the transom. Therefore, the bilge can be drained while on a lift or a trailer from within the boat without climbing underneath. This also helps maintain the integrity of the transom from water intrusion
Wow, that IS very nice!...Gucci class.
Maybe Gucci plus Lloyd's Register status for Capt Chuck!!
