Old 02-22-2015, 12:16 AM
slowJEEP slowJEEP is offline
Default Stretch 20
I've been working on the layout of my 20sf now that I've got it stripped down bare. I've got a small case of 2 foot itis and am thinking about adding in 2-3 feet just forward of the transom. I'm not expecting it to become a genuine 23 since they are significantly different boats. It just seems like an additional foot in front and a foot or two behind the console would go a long way to relieving the cramptitude.
As far as disturbing the hull design, I plan on adding a bracket so I've already departed from the original intent. Biggest opportunity for error I can figure is getting the cg located in a good spot. From a strength perspective, I'm gonna core the hullsides and probably increase the lateral cross section of the stringers either way.
Any thoughts?
Old 02-22-2015, 08:37 AM
I think that unless you are a boat designer, marine architect, or professional boat builder, that path is fraught with peril. Believe me, I understand the temptation to make big changes, but there are lots of potential unintended consequences. I would suggest that if a 20 doesn't have enough room, you should look for a project 23.
My $0.02
Dave
Blue Heron Boat Works
Old 02-22-2015, 09:39 AM
I spoke with bill potter yrs ago about putting a bracket on my 20' SF with the thought of getting more room inside and his recommendation was to just buy a 23!
Old 02-22-2015, 10:05 AM
I have to agree here. If a bracket alone isn't enough increase in space, then a 23 would be a better choice.
Old 02-22-2015, 12:41 PM
Thanks for the comments. That's the response I was expecting. Isn't there a saying about a man that refuses good advice?
Either way, I've already bought and ruined the 20 so I'm stuck with it from a sunk cost perspective.
Old 02-22-2015, 12:56 PM
FLexpat FLexpat is offline
If you are hell bent on streching the 20 you might be a lot better off doing a 24-30" stern extension than trying to splice sections in.
FWIW there is a 23 Tsunami w a bracket somewhere on ebay which might be even easier to cut cap off of.
Old 02-22-2015, 08:36 PM
Originally Posted by slowJEEP View Post
...I've already bought and ruined the 20 so I'm stuck with it from a sunk cost perspective.
What did you do that "ruined" it?
Dave
Old 02-22-2015, 09:16 PM
It's an 88' tracker. I've stripped it down to bare hull thus making it of little street value. Not a big deal in the long run but not a smart place to get out of a project either.
Never thought of a tiller.
Console is getting smaller for sure.
Old 02-23-2015, 06:02 PM
There is a pronounced wedge on my middle panel. I originally thought it was a defect.
Old 02-23-2015, 06:33 PM
Can someone post a picture of this "pronounced wedge" I'm reading about - not sure what this is referring to... thanks
