Old 07-29-2015, 05:25 PM
Copper Collar Copper Collar is offline
Default Hermco Bracket
Well after 18 months I finally filled out the pre order form on Hermco's website.
Old 07-29-2015, 07:21 PM
Best move I made on a bracket! I got his rigging kit also and very happy!
Old 07-30-2015, 10:05 AM
Your going to be in love.
Old 07-31-2015, 03:20 PM
Highwayman Highwayman is offline
Default Transom Angle
When measuring for Hermco's pre order form, are yall coming up with a 12 or 13 degree angle on the transom? Probably doesn't make any difference but mine is an unmodified factory twin I/O transom. Thanks
Old 07-31-2015, 03:57 PM
When I measured I got 14. When I talked to Don he said they were made at 13, but 14 isn't going to hurt anything.
Old 10-12-2015, 07:09 AM
The transoms I measure sometimes look closer to 14 then 13 due to the wood being rotten or due to when It gets replaced the weight of the new wood core makes it lay back a degree more. The one on my 20' is 14 degrees due to the heavy clamps that hung off the back while it set up. You can take a straight edge and lay across the back horizontally and you will probably see it touch mostly across the middle and there will be a 1/8th inch to 1/4" gap at the outer edges showing an outward crown in the back. Nothing a few tubes of 5200 wont fix. The next transom I did I took a cable to the front side and pulled it forward slightly while it set up to get it back to the 12.5-13 degree range. I wouldn't worry about the one degree difference a bit unless your transom is soft and sagging, then you may wont to fix that before the new one is installed.
Old 07-31-2015, 05:43 PM
And 14 bolts, nuts, washers, plates, and 11 tubes of 3M 5200 later......
Old 10-11-2015, 10:44 PM
Picked up my Hermco bracket a few days ago. I am very pleased in fact more than pleased with the quality and craftsmanship of the bracket. Don was more than helpful in answering my questions and provided detailed installation instructions for the bracket and rigging kit. A very pleasant experience throughout the entire process.
Old 10-12-2015, 05:53 PM
Two big thumbs up to Don from me to. Quality and craftsmanship are top notch, he was quick to respond to emails and phone calls, and on his own found more freight shippers to get the lowest price AFTER the original quote which I was fine with.
