Old 01-26-2016, 06:24 PM
bgreene bgreene is offline
Smile Seven Marine 627 hp outboard
All the discussion about best fit for 23' Sceptre.......twins 150's, 250, 300 hp
I'm thinking ONE of these and the boat becomes a " Super Sceptre."
Ok so at a bit over 1,000lbs somewhat heavy, but proper transom can handle.
Performance............now this is the fun part:
Cruise.....................maybe 45mph at 4,000 rpm ?
Fast cruise...............maybe 55mph at 4,500......
WOT.......................maybe 70mph +.....wide open, trimmed and tab'd just right.
How would it ride ? I'm thinking wow.
Old 01-26-2016, 07:20 PM
FLexpat FLexpat is offline
My 5.7 Bravo 1 I/O is just over 1000 lbs so I'm thinking the balance wouldn't be very far off. 627HP just might get it fast enough to chine walk a bit... I'm thinking more like 80+ if it doesn't start dancing first.
Old 01-26-2016, 07:44 PM
The 2009 Seacraft 26's were designed to go 65 with twin 250 Verados.
Old 01-26-2016, 08:05 PM
Humm..... I gained approx 8 mph with 50 extra hp....so let's just figure 15 mph per 100 hp.
With 300hp, I believe Scepter runs about 50mph. Since the rule of " diminishing returns " kicks in, speed increase per 100 hp will yield less.... but, fair enough even at 10mph per 100, 80mph seems possible !! ( assuming of course the hull can handle)
In sailboating, there's a term called " hull speed" meaning no matter how hard the wind blows, that hull will only reach approx X mph.
Seems the older 23 was a hull capable of speed.
Old 01-27-2016, 08:27 AM
I have seen pictures of 23's with twin 225's and twin 250's and the owners tend to say that after 65 they get scary as hell. The one guy with twin opti 225s said he got his up to 68 and that was with 8 people on board. He also said that with just him he never got passed 63. The weight kept it in the water and kept it from walking all over the place. You will never go safely over 70 in this hull with out major modifications. A motor like this would work good for an half throttle cruse of 60 plus but past that the top end would be wasted. Now from stop to 60 with the handles dropped would be one hell of an ride.
I think kmoose actually had twin 250s on his and he may can give you some actual experience. Im just going off what I have been told.
Old 01-27-2016, 10:13 AM
I had twin 225's on a bracket on a 23 SF. I was at three-quarter throttle at 60. Doodlebug had twin 250s on his Sceptre.
Old 01-27-2016, 01:27 PM
Doodlebugs rig was so stern heavy he had to power load
getting off the trailer.
Old 01-27-2016, 11:55 AM
You will never go safely over 70 in this hull with out major modifications. .
x2!
Bgreene - 23 seacraft is a kick ass fishing boat . . . no need to try to make it into something it's not If your objective is to go fast (above 55 - 60) there are much better hulls to work with than a 23 and power plants that have a superior power to weight ratio than seven marine engines.
see the nice pad on the Allison ^^
Old 02-12-2016, 12:50 PM
This was a friend of mine that had 30+ years of offshore racing experience. His 27 magnum was close to 70mph WOT. Going fast in a boat can get you killed.
http://www.offshoreonly.com/forums/m...fe-killed.html
Old 02-21-2016, 02:21 AM
I floated around the edges of high performance boating for a few years, occasionally dipping my toe in. Tim is right, high speed boating is EXTREMELY dangerous.
I began racing small "knee boats" (6'-8' class "A" hydroplanes) at the age of 7. I moved up to the B and C class at 9.
I quit dabbling in racing after stuffing a Gulf Wind Marine 30' Velocity at nearly 70 mph back in the early 80's off Ft. Lauderdale. Peeled the cap back like popping the top off a Tupperware. Analysis afterwards said I was probably about 1/4 of a second too early pulling the throttles back coming off a 3'-4' wave with a very steep backside. Result was dropping the nose and going through the next wave instead of over it. Driver broke his arm, I was just really banged up.
Any accident over about 45 mph can easily be fatal to everyone on board. I helped recover the body of a man who snap-rolled his 24' Martini at about only 40 mph right in front of Spencer Boat Works due to a broken steering cable. His girlfriend survived with a broken neck, his teen-aged son had broken ribs.
This doesn't mean going fast on the water isn't fun, the idea is to make it as safe as possible. I've rigged a 23' SeaVette with twin 235 Evinrudes for a customer, and we actually dropped the engines a bit to slow it down and make it less squirrely. I've also rigged a 2.4L Bridgeport on the back of a 20' SF that would easily top 60, but was pretty hard to control.
SeaCraft is a great hull for going fast in rough water - up to a point.
I know for a fact that the Seafari 20' handles very well in the 50-55 mph range. But I sure wouldn't want to go any faster than that! At 53 mph the Seafari is fairly dancing on the surface of the water, and at 55 it's just starting to want to fall off to one side or the other, as it's now up on the narrowest planing surfaces. That, by the way for those of you who don't recognize the signs, is the beginning of a chine walk, which can easily become the prelude to a snap-roll, where all passengers exit the ride suddenly.
Please remember that most offshore powerboat races with 21-25' V-hulls average less than 60 mph across the course/duration of a race. Occasionally you'll see a calm course where the average speed gets up closer to 70, but that's actually not common.
SO rigging a boat to go fast and then going fast = Fun! Rigging a boat to go stupid fast and then being stupid = not so much.
Fr. Frank says:
Currently without a SeaCraft
