Estimated 30 mph top speed seems like either tired outboard, or heavy logged hull correct ?
80's 23's are heavier hulls and have a larger fuel tanks. You'd have to work hard to only get 30mph out of it . . . even with the bottom covered in barnacles dragging buckets and running on 5 cylinders you should still be able hit 30mph. There were different flavors of yamaha 225 (2.6L 225 1989 - 1992) yamaha excel 225 2.6L (86 - 89'ish) and then the large 3.1L displacement versions after 1992 (v76, ox66, etc.)
The old excels were strong engines. Had a friend with a Paramount that would bang 60 with one. Couldn't kill it.
[b]The Moose is Loose ! |
What prop?
I have a 1977 Sceptre and run a 1988 Yamaha V-6 Excel (225hp). Last summer at WOT (5800rpms) I ran 43 mph with a light load.
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
That's what I figured, something likely wrong......
43mph = 37kts
do not let common sense get in your way |
I agree. You either dropped a cylinder or are caring an external 3000#'s of aqua in the hull. That set up should run 40-42 wot with the the "wrong" prop. Something is amiss.
"estimated"....
