Good afternoon, Seacrafters.
I am working to refurbish the teak in the cockpit of my 1976 Sceptre, which had been somewhat neglected. It's coming out reasonably well considering it's my first time varnishing. Will post some pictures when it's done and installed. ![]() But right now I'm looking for advice regarding the stock original glovebox cover. It's pretty beat up and looks it (see pic attached) I searched this site for ideas and found a couple of threads from 10 years ago. One owner had looked to find a source for the faux wood grain stock but there were no replies. I saw a picture of a dark plastic replacement cover with laser etched 'Sceptre by Seacraft' logo IIRC. Ideally, I would like to get some teak veneer glued on, to match the wood on the boat, but that would mean not having the nice 'Sceptre' logo. How could the logo be replicated if I do get the veneer? Laser? Other ideas? TIA, Jon Brush Boston and Shelter Island, NY |
PM sent.
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
Hi Jon-
I would contact Flounder Pounder Marine in Florida. They make a bunch of faux woodgrain instrument panels for Sea Ray's and i am sure that making the glove box lid for your Seacraft would be a no brainer. Ed |
Thanks,
Your boat is the one I found in the archives. Responded to your pm. Jon |
I laminated multiple layers of glass on a layup table to match thickness of original panel. Pressed it down flat, cured, cut it to size glass and gel coated… Looks stock….
Thanks, pm sent
I bought a 4X8 sheet of teak veneer from a local imported lumber distributor in Beaufort NC. It's quite thin and has a wood backing rather than the usual paper. For application to a flat surface, like the old glove box lid, 3M High Strength 90 spray contact adhesive works well. You can then varnish with your choice of finishes. I also did the underneath side of the cabin hatch, which looks a lot better than the ratty carpet that was originally there. (Used epoxy for the adhesive with lots of weights to hold in place since there were curves.) Any sign shop can do vinyl letters/logo to apply.
1974 23' Tsunami, fully refurbished, custom pilothouse, Hermco Bracket, 250 Etec 1977 23' Sceptre fully refurbished, soft top, I/O |
Thanks so much.
![]() Jon |
Handful - I've always liked the underside of your hatch and how you cleaned up the dash.
Hey JonBrush,
I have the same original glove box. I lightly sanded mine down and put a light stain on it and followed up with a couple coats of Varnish. Turned out great. Folks ask me if its new. It is a little lighter than the varnished teak but 100% original! EB |
