Old 08-16-2016, 05:58 PM
rcnight rcnight is offline
Default Evinrude Gremlin
I was running in this past weekend trying to outrun the approaching storm when my 1997 Evinrude 150 went from 5k to 0 rpms in a few seconds. No fault lites and no warning of oncoming problem, ran fine all day. A passing boater was kind enough to tow us the remaining mile or so. Tried to start it on the way in with no luck. Would crank but wouldn't fire. I went out to the boat today to check for spark and it cranked right up. I did replace the kill switch recently. I checked the wiring and all good. What would cause such a rapid cut-off? Any ideas on what and where to look?
Old 08-16-2016, 06:26 PM
Start by looking at your kill switch again. That would do it. I think it's the black and yellow trace wire that kills the spark.
1974 23SF
Old 08-17-2016, 03:09 AM
natecert natecert is offline
Correct it is that wire. Would suggest doing a visual on the wire and all connections involved with the kill circuit. Also try running on mufs and wiggle all the wires in the start/run kill circuits. You may get lucky.
Recommend to invest in a good multi meter. Fluke or field-piece would be my preference. If you want to PM me I can help you with picking the model out.
HVAC is my trade and electric trace down is my fav. thing.
Ed
Old 08-17-2016, 05:07 PM
76Red18 76Red18 is offline
Starting circuit wires as mentioned. My key switch would intermittently cause a loss of power. Had to replace it. Check your power pack ground wire. Black wire from pack to a coil mounting bolt. Clean both fine pin connectors at the top of the pack with alcohol or degreaser. NO dielectric grease or anything else on those on those connections. If the power pack is original, it could very well be failing. It can be troubleshooted with a manual and the right test equipment.
J. M. Hendrix
Old 08-17-2016, 06:38 PM
Default Dirty Ignition Switches
Don't know if this happens on boats, but I once had a '68 Corvette that would occasionally die, coast to the side of the road, and then immediately restart. Then one day as I turned the key, it started until I let go of the key, had to keep some torque on the key to keep it running. With a paper towel and WD40 and pushing the key in & out, I washed a lot of debris out of the switch. Probably had the car 10-15 years more with no ignition switch problems thereafter. Probably not your issue, but a quick thing to try.
Old 09-08-2016, 10:32 PM
martin martin is offline
68 vette... I'm drooling now
Old 08-16-2016, 06:35 PM
TomParis TomParis is offline
I have a 1999 Evinrude FICHT, and it has been overall operating fine for me, but on occasion it will do something similar and just without warning cutoff. Usually after a minute of sitting it will start again and go the rest of the way without anymore failures. It is very odd for sure.
Old 06-14-2017, 04:28 PM
It shouldn't start with the throttle advanced at all. The yellow red tracer wire is to prevent that. Its a safety wire so it doesn't start in gear. It may turn over easier in an advanced throttle position due to the butterflys being open.
The yellow wire red tracer can kill it. you can bypass that switch (neutral safety switch) by tying them together but be careful it will then start in gear.
1974 23SF
Old 06-14-2017, 07:23 PM
Neutral safety switch maybe.
Old 06-22-2017, 02:19 PM
I've had very similar issues on my 2004 150hp Johnson.
