Old 10-12-2016, 08:08 AM
TPG TPG is offline
Default Another 20 resurrection
So have a sad neglected 1971 20 super fisherman sitting in my driveway.
The current plan:
Onto a dolly and into the garage
Transom job
from the outside, due to wanting to keep the storage and livewell
6 inch lip, the wood is REALLY gone so I don't have any fears of having issues removing it all
epoxy and marine plywood
Deck job
gonna raise the deck 2 inches and make the old scuppers go away and plumb through the transom.
foam core, could use some advice on what thickness to use, most likely polyester resin instead of epoxy due to amount and cost.
Old 10-12-2016, 08:11 AM
TPG TPG is offline
A little work done so far:
Console shaping up
Dolly half built, still have some reinforcing to do, and maybe add a center 4x4 for support
Bad transom, really really bad transom
Old 10-12-2016, 12:48 PM
Let the fun begin!
Old 10-14-2016, 10:18 AM
TPG TPG is offline
Lets do this.
Tuesday I cut the outer skin off after work, and started digging.
Quick bash this AM
Hoping to get the skin area wood out at lunch today.
Started drilling holes with a hole auger into the plywood to start cutting between the skins. Still need to cut the cap off the transom so I can work from the top down with chisels.
(That notch on stbd the previous previous idiot I mean owner figured it'd be easier to notch the transom for a kicker instead of just putting a kicker mount on)
Old 10-17-2016, 08:10 PM
linesider36 linesider36 is offline
Did you save the Hull ID#, I hope.
Old 10-17-2016, 09:21 PM
TPG TPG is offline
Yup, also 71 is pre HIN.
Old 10-14-2016, 12:36 PM
TPG TPG is offline
Core thats left: meet chisel. Time to cut the tap off the transom area so I can start from the top down.
Whats up with the staples?
So I decided bleeding was overrated and have been using my Oakley tactical gloves. They're a damn godsend.
Old 10-14-2016, 12:42 PM
FLexpat FLexpat is offline
I think they were used to hold the two sheets of plywood together during cutting and assembly
Old 10-14-2016, 02:29 PM
I'm happy you mentioned the lower starboard side of the transom, I thought I had a couple too many scotches!!
Old 10-14-2016, 04:51 PM
TPG TPG is offline
Clearly someone from the past had a couple too many something....
