Old 02-10-2017, 10:48 AM
jm9919 jm9919 is offline
Default Reuse scuppers
Hey how's everybody doing my question is,I was able to pull the original scuppers out of my 1980 seacraft it's a 20-foot overnighter,should I put in new brass covers or should I just reuse the original ones, they are in great shape and came out with no damage whatsoever. I am trying to post pics but I'm not able to, I will post them as soon as I figure it out.thanks
Old 02-13-2017, 02:09 PM
Go with new brass tubes, they are $5 ea. and you'll likely have trouble getting a good flare seal with the old brass. Damage may be all but invisible. Flaring tool is $20:
https://www.amazon.com/520290-1-Drai.../dp/B0082ANA0C
You'll likely need a longer bolt.
I used 3M 4200 for sealing figuring some flex would reduce possibility cracking and separation with weather changes,
Old 02-13-2017, 03:36 PM
Google "Annealing" brass. Not the worst job. Buy extra length. I have a spare section, 30" one inch outside diameter brass tubing from my Whaler refurbs. Probably enough to split with another member, I think Jorge in Miami may be doing similar project
Vezo. Part II
Old 02-13-2017, 03:37 PM
Try McMaster-Carr vs. Amazon.
Old 02-14-2017, 12:29 PM
Default reuse scuppers
do most seacraft boats have brass scuppers,cause the ones on my overnighter are plastic???
Old 02-14-2017, 01:09 PM
Pretty sure everything from the '70s and early '80s, had brass tubes. Maybe it changed. Many guys have replaced brass w plastic, fiberglass or pvc. Post some pics of yours if you can. Not sure about the overnighter. I've never seen one in person. In other models w/ thru-hull scuppers, the problem became rot in the wooden supporting blocks as much as the tubing.
beastly's overnighter in below link shows scuppers but I can't really tell if they are plastic from the picture. I don't know if original or not.
http://www.classicseacraft.com/commu...ht=overnighter
