Old 08-22-2017, 05:49 PM
agsmoke agsmoke is offline
Default Trailer recommendation
I need a trailer for a 2006 SC20. Does anyone here know the true weight of the boat. I am looking for an aluminum trailer with at least 14" wheels. Does anyone here have a recommendation on a good trailer.
Old 08-22-2017, 06:08 PM
Not sure where you are but Owens and Sons, Aluminum Slide-On, is damn close to the best, custom built to your hull and less expensive than a generic cookie cutter. Ask me how I know. Check it out for yourself.
Vezo.
Old 08-22-2017, 06:52 PM
Where you located?
Old 08-23-2017, 12:20 PM
I am located in Jupiter, Florida
Old 08-23-2017, 12:45 PM
Short drive. Here's the deal. Jeff knows SeaCraft hulls very well. He will measure distance between outer chines and build, bend aluminum I-Beams to that measurement. Then he secures pressure treated bunks directly over the I-Beams, and hull is locked in, carrying all weight on the I-Beams themselves, and transferring weight down to torsion axles. The weight of the load is not sitting on adjustable bunks secured to cross members of all the generic cookie cutter trailers out there. And cheaper, including all Stainless Steel, led lights, spare hub and wheel mount. He even uses heavy grade extension cord for wiring, which is standard. You will not believe the quality. A twenty usually requires a random and brakes on one axle in Florida. Jeff is the knowledge, his sister Kim runs the office, and can't think of brothers name who runs production. Located in St. Pete. You owe yourself a call into them after completing your research. I've owned three, my brother has one under his 18 SF and two other neighbors have purchased after seeing mine.
Vezo.
Old 08-23-2017, 12:49 PM
Thanks I just called him. Jim
Old 08-23-2017, 12:59 PM
Were you impressed? I may even be able to deliver it for you. Have friends I need to see in Palm (City?), very close to Jupiter/Stuart.
Michael.
Old 08-22-2017, 10:40 PM
dginge dginge is offline
I have the same boat. My trailer is a ez loader 2003 model. It's a great one.
The dry hull weight of your boat is 1600-1800. With gas and a four stroke you are around 3k pounds
