2002 21 CC. Just bought this boat about 3 weeks ago. I bought it with about a 1/2 tank. Today I put 20 gals. in with Valve Tec. Launched the boat and ran it for about an hour. There is defiantly fuel in the bilge. So I assume the fill hose has a leak. I can't understand why SeaCraft ran the fill so far FWD. Anyway what is involved checking the hose and or replacing it. Thanks,Dave
Defiant fuel can ruin your whole day.
Forevah. |
riggin hole??
The hole in the deck under the console where the riggin` goes to the engine.
Try and remove the fill fitting screws. Do all but one come out? If so one on the screws is a machine screw with a nut on the backside. |
That's what I plan to do next. Probably this afternoon when it stops raining. Why would they nut and bolt it. Really! Thanks for the heads up.
That's comforting. I'm thinking it might be the hose. Only because if it was the tank I would think it would be still leaking in the bilge. Wishful thinking!! I'm going to pull the fill neck flange to see if I can see anything.
I'll make no assumptions, and will hope it's just a hose -- but do re-read and assess Don V's post (the bad news part).
that hose is long and has a sag under the fwd casting deck, that is where gas sits, if you fill and don't use the boat , gas sits and rots inside of hose..your 2001 is the same hull as my 98...call me again on your cell and I text you px of mine with floor out and what I did after new tank
Joe R. 21 SeaCraft 1998 /200 Optimax
Joe R |
