I'm sure it's been discussed previously, but what is the preferred bedding for an aluminum fuel tank?
I remember reading not to set it on neoprene? Or was that some other type of rubber? That the rubbber would promote electrolysis. This is not for my SeaCraft but my Chris-Craft - twin 150 gallon tanks. Thanks for any insight! |
Neoprene. Pascoe (I think) has this well documented.
first - solvent clean,scuff sand,solvent clean again - chemical etch prime,followed by either interprotect 2000 or coal tar epoxy,to the correct thickness...
setting tanks - starboard strips,these will work the best,setting the tank up,off any flat surface,allowing moisture under it to pass. rubber,neoprene - these will actually trap water/moisture.
do not let common sense get in your way |
![]() Quote:
Island Marine Group, LLC www.islandmarinegroup.com |
Thanks to all replies!
Lots of good info Thanks again |
If you haven't had the tank built or coated yet weld some 1"x1" or 1 1/2" angle to the top of the tanks so you can screw them to blocking glassed to the side of the stingers for support. That is if it will work out in the chris-craft stringer layout where you are placing them.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
thanks Friz! -
the tanks just sit on top of the stringers (4"x 8" )- above all / under the deck they were originally just "corralled in" with 2x4's i'm going to have brackets welded along to bottom to lag into the stringers thanks! |
