Old 03-29-2018, 09:38 PM
Default Stoner Boatworks bracket
Hey guys. Here it is. Not installed yet, but just finished. Josh from Stoner Boatworks just sent me the finished pics of my bracket. It looks amazing and I can't wait to install it. More progress pics to come once I receive it.
Old 03-29-2018, 10:00 PM
Sweeeeet!! I like the dive platform higher up on the tub.
Old 03-29-2018, 11:05 PM
Very nice! That looks a lot different than the old hermco bracket. I thought Stoner got the molds from Don.
That bracket looks like it has plenty of room for Trim Tab actuators under the swim platform.
Old 03-30-2018, 09:27 AM
Yes Sir! I asked Josh if the standard Bennett tabs fit without "notching" the platform with his platform being about 3" higher then the Hermco and he said they will...unless there is a very sharp dead rise at the transom, which reduces the vertical clearance out towards the hull . In most cases they have no problem with clearance, Mr. jnamowtiz can let us know. To me the larger "foot print" of the tub against the hull looks much stronger. The higher platform is very similar to the way Armstrong builds their brackets.
Old 03-30-2018, 12:28 PM
I will definitely let you know once I receive it. I’m hoping my math comes out right. I know where my water line was with the IO and trying to figure out the height to mount the bracket is gonna be a bit tricky
Old 03-30-2018, 01:20 PM
Very nice! can't wait to see it on the boat
Old 05-23-2018, 02:32 PM
Here are the finished pics. I am super excited to get the engine mounted next week.
Old 05-23-2018, 03:47 PM
fredbrad fredbrad is offline
It looks wonderful,I think it will work perfect on your seacraft, I have built something similar to the Stoner bracket and only what I need to be sure of the height from the keel to the motor top mount,on mine is 29"(set back is 27" and for a 25"motor shaft),could you please take the measure for me?. I'm hesitating if it would be necessary to cut it an inch and leave it at 28 ", so would the anticavitation plate around 3" above the bottom level of the boat
Old 05-23-2018, 04:02 PM
I mounted mine at 27” up from the bottom of the boat. It has a 28” setback.
Old 04-02-2018, 09:03 PM
Jetskirider305 Jetskirider305 is offline
Love the bracket where is the shop located and their phone #? Thanks
