Old 08-21-2018, 05:50 PM
bgreene bgreene is offline
Default Early vs later gen seacraft
Legend of “ Potter built” era seems to be consistently favorable.
Builder I respect had told me the Tracker actually used more fiberglass.
Interested in other expert comments
Old 08-21-2018, 06:15 PM
Shotgunwilly1117 Shotgunwilly1117 is offline
They did use more fiberglass but that doesn’t help if it’s not done correctly.
Old 08-21-2018, 06:36 PM
fishingproblem fishingproblem is offline
Great first post and I already like you.
Old 08-21-2018, 06:58 PM
Oops, I should have had this post in " General" forum....
I did a search and found lots of previous posts on this subject...
Old 08-22-2018, 07:38 AM
ALL of the 1987 Tracker 18' and 20' boats and all the 1988 18' hulls were actually built by SeaCraft Industries before the Tracker purchase, and finished by the same folks after Tracker bought the company. Most of the '87 23' boats were also built by SCI except the 1987 23' WA, where the first 8 WA hulls were laid by SCI, but the caps and liners were built by Tracker.
(I managed a marina back then where we were SeaCraft dealers, both before and after the Tracker take-over).
Fr. Frank says:
Currently without a SeaCraft
Old 08-22-2018, 03:24 PM
captainDH captainDH is offline
this is actually very true, so Hermit, not really sure how that question can be answered. i was always told by Mac Privott at Albemarle when questioning the use of chopper gun is not as good as hand laid glass. his response was "the secret is the man behind the gun, as he knows how/where to apply for maximum strength". all i can say is that boat building materials have highly evolved since the 60s/70s/80s, as so has the techniques. the newer boats have no wood/composite construction, and none of us seems to see any rebuild pics/threads on the newer boats, only the older boats. there should be some merit to that point, even though the tracker era boats "get no love".. mine gets plenty from me. can't wait to see if the transom can hold up with either a 350 or 400R down the road, as they are available in 30" legs as well. no heavier than my current Gen 1 250 Vrod at 670 lbs now.
Old 08-22-2018, 07:24 PM
The bad part about the "new" 1998 - 2008 seacrafts is the fuel tank access. There's no fuel tank hatch. When the hoses go bad or the tank gets a pin hole leak (which will happen soon) you have to cut the floor open.
I went shopping for a "new/used" 21/23 seacrafts last year for my father in law. The four 1998 - 2005 boats with under 600 hours plenty of stress cracks. 3 of the 4 were beat up worse than my 73 hull which I fish commercially.
Old 08-22-2018, 07:52 PM
Not good...….. yeh, Ive seen some big money boats with gel bubbles, voids etc.....
By late gen Seacraft I refer to the mid - late 80's Sceptre…….vs the Potter 70's.
General consensus seems to be both fine, with the Potter enjoying the " mystique" and Tracker maybe actually more fiberglass in the build...……...but without the original family build connection.
Old 08-22-2018, 08:02 PM
More fiberglass ??
Here is your more fiberglass from a 1970 SF !
The one on top was from the 3/4 hole hole drilled into the bottom
for a wash down pump and the bottom one into the splash well...
Backin' the day they were unsure how much glass was needed to
keep them together !!
They are all still SeaCrafts...
Old 08-22-2018, 08:31 AM
i own a 2005 classic 23, know another friend who has an 06' version, and know of a few friends who have had potters....so here is my take....
i am very aware of all of the "bass pro special" bashing that the newer boats get. i have read every thread about these boats. i have concluded that most of the issues were with the 32s and 25s, the issues were hit or miss with the 23, most 21s were tight, and the 20s seemed to be ok as well other than the self bailing issues. i studied everything i could about my 23 including calling the prior owners before i purchased it from the then at time current owner. bottom line is that most of the potters, either you buy one that has already been restored, or it's more or less a project. few are still perfectly solid that are 100% original, and if they are perfectly solid, tank still original but good, they bring even more money but yet the next trip out in the boat you could face a problem not yet discovered. while the newer BPS boats are treated like the red headed step children, i can honestly say they are all composite, no wood, solid as a tank, and mine has zero stress cracks anywhere. really all i have to do is upgrade electronics and eventually repower, as to be expected with any boat of this vintage. that being said, my friends who had the potters and rode in mine, actually said mine rides as good if not better as it just felt heavier and more solid. no shakes, squeaks, rattles, nothing.... so I'm a fan of all of them, but seems like the BPS era boats are no way near even close to restoration phases yet due to composite construction. seems like the logical way to go, and feel that other current owners must feel the same way as well, as just take a look at the market, they are truly hard to find.
and just as FYI to Bgreene, i am the empty cannibal on THT, who had the 4 albemarles.
