I'm starting to get my console played out.
Planing to go with the following Garmin 94sv GPS/Fish Finder Standard Horizon GX1300 VHF Fusion RA70 Stereo A tach, Gas gauge, Volt meter. A switch panel with Bocatech switches and a 12voly plug. My question is how many switches will I need? I have 2 bilge pumps, 1 baitwell pump, that needs to connect. I know I need 1 nav lights, and I want some under the gunnel lighting and 1 for the future t-top lights. How many do I really need with not going overboard? Is 8 enough? |
How many loads do you want switched and how many loads do you want wired to a fuse panel?
I'm restoring an old Whaler and just pre-wired the console while it was out of the boat. I elected to only have 3 switched loads and with one spare; Nav lights, Courtesy lights, manual bilge pump. 12V outlet, GPS, Stereo will be to fuse panel. |
You might want one for a wash down pump or even
locker lights ? (every compartment has a light) ... Two that I have on "Bones" that are used on a regular basis. Here are before and after on my Seafari project currently underway.. ![]() Before: After: LED backlit from "Bonestech" ... ![]() NoBones stable mate "No Intention" ... ![]() ![]()
See ya, Ken © |
Bad Azz
Tarpun 1972 20 Seafari 1977 23 Savage 1980 20'Master Angler |
Nice job
I just had this panel made up, to give you some ideas...
I like it!!!
I sent you a PM for additional info from you |
Didn't see a PM come through.
I like your new layout. Wondering about the VHF over the fusion radio... the mic wire may hang over the fusion a bit.. I'm having trouble figuring out where to put mine. |
Who made your switch panel?
So here's what I'm initially thinking
1 Garmin 94 sv in the middle Standard Horizon vhf to the left Fusion stereo under the vhf To the right goes the tach fuel volt and water temp gauges Underneath goes the panel with 8 switches a 12 volt power suppy and USB port Would like to go with Bocatech switches but have not made up my mind or the budget |
