Old 04-10-2021, 09:46 AM
Rbphipper Rbphipper is offline
Default 72 20' new deck
I've been researching this site as it's my go to bible with the wealth of information and truly appreciated experience. However I cannot seem to find deck replacements when keeping the liner in. I'm struggling with the decision to lay in a new core on top of the old glass, which is in good shape yet wavy, or cutting bottom glass layer out, raising stringers and mounting side cleats on liner. I really don't want to rip this whole thing apart as I'm short on time and weather in NJ. I did replace transom with Coosa using the West System as a guide and increased height to 26 1/2, based on many CBC restores. I am open to all suggestions. Thanks all!
Old 04-10-2021, 11:20 AM
Since you and coosa are already friends Cut the old wood out and top it off with 1/2 or 3/4 coosa. You already have a 2" ledge to lay it on and tab to the sides. 1708 on the top and bottom of the coosa and it's done forever. If you want to add strength to where the CC mounts, epoxy some 1x2 hard wood strips to the underside of the new coosa floor for the screws to go in to. Have fun!!
Old 04-11-2021, 09:03 AM
Hi Don, Thank you for the reply. So I already chiseled out everything to the original underside roven/MAT. Should I just leave that intact and glue spacer strips over the stringers? I wanted to use 1/2 inch coring material, but most on this site seem to go with 3/4. The original was 3/8 balsa / wood mix core, so I'm thinking 3/4 may be overkill and extra unneeded weight?
Old 04-13-2021, 08:32 AM
What was your layup topside and bottom, and how much epoxy did you use? Trying to get my order together.
Old 04-11-2021, 10:24 AM
You are way too patient!! I would have cut it all out....seems easier to me and I'm lazy. I've only seen 3/4 used, in coosa that is a very small difference in weight. Only 17 pounds for a 4x8 sheet. However with 1708 on the top and bottom of 1/2 coosa there is no reason to think it would not be strong enough. I would for sure use backing plates for the CC and leaning post bolts/screws for 1/2.
http://coosacomposites.com/pdfs/coosa_weightchart.pdf
Old 04-11-2021, 11:13 AM
I replaced my deck with 1/2 inch Nida Core with a bottom layer of glass and 1704 on the top....came out solid. I also layed some wood were the t-top and console go. And idea is to drill out the wood were the screws go fill in with ...can remember what...and then screw it into that. It will never rot again
Old 04-11-2021, 11:14 AM
Well this is my first (and probably last) attempt to getting the boat I've loved since the 70's, so I'm trying to get it right the first time. I think I was afraid to see what was underneath, cause it would likely lead me to raising stringers, new foam, new belly tank..... blah blah blah.....lol $$$$$$. Here's one for you'll, a dove nested in my ladder and wife wants me to wait until eggs hatch and they've flown the coup. Any suggestions (other than getting rid of the wife) lol
Old 04-11-2021, 11:33 AM
Jorge..... did you leave liner in and basically do what DonV said?
Old 04-11-2021, 11:35 AM
.......and what type glass did you put on bottom,:matt or 1704? Also, epoxy or poly?
Old 04-11-2021, 04:23 PM
I left the skin that was on the bottom of the deck and added some glass clothe to stiffen it some. Then the 1/2 inch Nida Core then 1704.
If I were to do it again I would have cut it all out
