Old 04-13-2021, 09:39 PM
jsylvester08 jsylvester08 is offline
Default Wet Transom- help
So I went to move my Lowrance transducer and decided to repair another old patch that looks like an old screw hole. So I drilled it out to reseal it and water started to drip out. It’s right next to the transom drain. I knocked on the rest and seems very solid but how concerned should I be? It’s a 1986 20SF. You can see in the picture it looks like it was seeping but I’ve never noticed it before. I really don’t want to replace and loose the season. Anyone run use epoxy to fill the small void and get a few more years out of it? Any help would be great.
Old 04-14-2021, 09:19 AM
take a potter take a potter is offline
I got a few more years out of mine. The question is how do you know if yours will make it. A couple of things to look for/keep an eye on. First tilt the motor up and have a robust friend put pressure on the end of the lower unit, while you watch the transom. If you can detect any flex then I would be very cautious, once movement starts it can progress pretty fast. Look carefully at the outer edges of the transom, under where the lifting rings are, if you see hairline cracks running vertically, then I would say you are done. On mine when I saw the cracks running almost top to bottom on the outer edge, almost at the corner I knew it was past time. When I got into it that was confirmed.
By the way this was on an original 1975 transom. If yours has been molested previously, your situation may be different. This is just one guys opinion on the internet, and I have only done one transom. Many on here have done multiples and might have some additional thoughts.
Old 04-14-2021, 09:26 PM
Kwaugh5p Kwaugh5p is offline
My transom felt really solid also. I had a friend who was a marine surveyor put a moisture meter on it and he found out the entire transom was wet. When I removed my trim tabs water also drained from a screw hole. Long story short when they started replacing my transom this is what the wood looked like. Mind you it is a 1972 boat.
Old 04-15-2021, 08:52 AM
captsuperfly captsuperfly is offline
Ugh, sorry.
you could drill a few more exploratory holes to see what you find... but as the others have mentioned it's often shocking how wet our solid feeling transoms were when we took them apart. Even if some of the wood dries out, it's almost inevitably de-bonded from the skin.
Drilling in a bit it really the only way to know for sure. Good luck.
Old 04-15-2021, 09:33 AM
My 18 transom felt solid and...
http://www.classicseacraft.com/commu...1&d=1618493583
Old 04-15-2021, 11:09 AM
When I did my transom it was before the garbage man had hydraulic equipment to pick up the cans, he was not real happy for a week or so with my wet transom wood!! Amazing how heavy that goo is!!
Old 04-15-2021, 11:33 AM
steel686 steel686 is offline
Doesn’t smell that great either as I recall. I have a video where I removed the battery box platform starboard aft and water was running out. Didn’t have any evidence on the exterior of the transom. No cracks or flexing. Happy I didn’t hang a new motor on it after peeling/wringing it out. Sorry to add on but check out a few pictures. You’ll sleep better if you bite the bullet.
Old 04-15-2021, 11:56 PM
Default Thoughts on cost
Thanks all for sharing not the news I was hoping for but not surprised. Any ball park ideas of the cost of replacing the transom at a shop? Can anyone suggest any good shops on Long Island. Prob look to do it in the fall but we’ll see.
Old 04-16-2021, 11:40 AM
In my area probably around 5000 for composite
Old 04-16-2021, 12:45 PM
Been on LI for the US Opens at Bethpage and Shinnecock and comparing prices from FL to LI is impossible. What would cost $3,000 here for a new transom could be well over $5,000+ up there. Good luck!!!
