Old 09-18-2021, 10:15 AM
Lightbulb Yamaha F70 on a 20 MA?
Toying with the idea of a rehab- cleaning the carbs and fixing the tilt/ trim on my Yamaha F100 and selling it.
Then finally fixing the transom on my 20 MA with coosa and divinycel.
A Yamaha F70 with EFI is 253 lbs. Versus 363lb or so for the F100.That and a foam transom, and needing and carrying less fuel has me wondering.
I think this is a question for Fr Frank.
This boat is too small and light to go fast in a Buzzards Bay chop. I always try with the F100 and never can air it out. This may astonish some of you, but it gets airborne too often with just a F100. I can't get to 30 statute MPH on any sort of regular basis.
This would never work for a Florida boat, I know. But a new, light EFI engine is appealing. And kind of fits with the Mosely vibe of "light is right".
No raising decks, no worrying about flooded scuppers, no worry about center of gravity...
Old 09-20-2021, 07:44 AM
DoozleD DoozleD is offline
i had a f115, the thing was a dog. had no balls.
Old 09-20-2021, 03:15 PM
A long time ago, I was fishing/camping with several friend in the Keys. One of my friends had a 22Aquasport with twin 70s. One of his motors quit on him and he couldn’t quite get the boat to plane going home. We threw him a long rope and we cruised the 25 miles or so back to dock. I think if he could have ditched the dead motor and maybe put a different prop on it, he could have made it without any help.
Old 09-20-2021, 06:58 PM
So you pulled him up on a plane and then retrieved the rope and and both boats cruised home on a plane?
Old 09-20-2021, 05:56 PM
Better have more and not need it than need it and not have it
Old 09-20-2021, 07:29 PM
No, we did try that, but he could not keep up, so we hooked up again and just stayed that way. There were no waves to worry about. Maybe if we transferred all weight to another boat, it would have been better and I think that could be an issue on the 20. Keep a light load and put the right prop on and I think it would work.
Old 09-21-2021, 06:41 PM
I actually did rig 1 (one) 20' with an Evinrude 70 back in the early 80's. It could get the boat on plane but was clearly inadequate. But customer is always right, eh?
I think 85-115 hp is the right HP range for the 20' if you're worried about weight. Your F100 is a good motor . If you're getting airborne in the heavy chop trying running with the motor trimmed all the way down. Adjust your propeller torque tab for that configuration. Alternatively, and better yet, let me suggest adjustable trim tabs. Keep the nose down and it's much harder to get airborne.
The 20' was designed for a single 275-315 lb outboard, or in the case of some of the wide transom cut-out models of '68-73, up to twin 50-65 hp motors at 190 lbs each.
The very first Seafari I rigged back in '83 was a '69 re-rigged from its original twin 190 lb '69 Johnson 55 hp 3-cylinders to a single Mercury 140 ELPT inline 6 weighing in a bit over 300 lbs
Fr. Frank says:
Currently without a SeaCraft
Old 09-21-2021, 08:24 PM
Just curious, was that motor rated at the crankshaft?
Old 09-21-2021, 08:36 PM
doug7488 doug7488 is offline
Default 70 on 20 MA
I’ve recently repowered my 77 Seafari 20’ with a 115 Etec
I feel it’s borderline acceptable
If I had to do it over I’d go with a 150
Old 09-22-2021, 02:36 PM
fishstu fishstu is offline
A 70 hp would get a SC 20 on plane if it is lightly loaded - pretty sure that the boat performance would be limited with say 4 guys with gear on board . I think the Mercury 115 hp 4stroke is a great fit for the SC 20 - I have 150 Etec on mine which can push the boat faster than I need to go.
