Old 05-01-2002, 03:12 PM
TonyS TonyS is offline
Default 23' twin engine blowout problem
I have a 1986 SeaCraft walkaround cuddy, with twin 1988 mercury 135's. I have a problem with the props blowing out around 2000 to 2300 and I have to slow down or pick up speed till they bit.
I was told the engines sit to high on the transom. The engine have 25" shafts and are mount all the way down. Can anybody HELP.
Old 05-01-2002, 04:17 PM
Hooper Hooper is offline
Default Re: 23' twin engine blowout problem
Tony,
I am no expert by any stretch but I run a 25" shaft on my 23' CC. I have a single outboard, a Mariner, and it gives me no trouble, I am thinking, with twins, they would sit more outboard from the keel thus the hull bottom should be drawing less water than at the keel right? Strange problem...but, I think that somewhere in this site, someone will have a suggestion for you. I bet someone has had that problem before and can correct it. Sorry I cant help you more....Gordon
Old 05-01-2002, 04:49 PM
Hooper, Thank you for your reply. I forgot to say that my center line on the transom is 31"s, I think the boat built in the 80's had deeper center line then the early ones. Your boat may be more of a classic then the one I have. But I LOVE MY BOAT.
Old 05-01-2002, 04:50 PM
Scott Scott is offline
Tony and Hooper welcome to the site!
Tony like Hooper says I'm no expert but your not getting clean water for some reason....I would however be inclined to think that if you have a 30" transom with twin motors with 25" shafts your good. There’s a lot of stuff you could look at.
Thru hull / Transducers causing turbulence in front of the props?
I would guess that you've made sure the cavitation plates are on the same plane with the bottom of the boat?
What about the props are they the right ones for the motors.... pitch??
Have you messed around with the trim while running?
The only time I've experienced this has been when air has gotten under the boat and the props got caught in the wash.
Not alot of help but some things to consider if you havent already..
Scott
Old 05-01-2002, 04:57 PM
Scott Thank you, I tried everything you said. I think the one thing I did not try, is a new setup. The engine cavitation plates are 1" above the transom. Do you know the proper setup. (spacing and transom hight).
Old 05-01-2002, 05:36 PM
Tony
My engine is about even (a single) with the bottom. You wouldn’t want to go higher than that(the 1" even though I don’t think that’s too high) but if you could lower the engines a little it wouldn’t hurt......just more drag. Doesn’t sound like that can be done though [img]images/icons/confused.gif[/img]
Trayder ... where's the cavitation plates on the Contender??? or anyone else???
Has the boat always done this.....and does it do it when on plane??
Old 05-01-2002, 06:21 PM
Trayder, I had the boat for 3 yrs. it has been doing it since I got her. I thought it was going to be an easy fix !!! Once she is on plane she will run fine. My props are mirage 15x15.5 and my max RPMs. are 5200. (The engine max are 5000 to 5500), so its in the range. I was hoping it was a prop problem..
Old 05-01-2002, 06:37 PM
hermco hermco is offline
Tony,
What is the engine center to center measurement?You can find by measuring from left mounting bolt center on one motor to left bolt center on other motor.
d.h. [img]images/icons/smile.gif[/img]
Old 05-01-2002, 10:20 PM
Trayder Trayder is offline
Velvet Jones
Hello guys-
DH would be the authority on this one. I have not checked the measurements on The Contender yet but regardless D.H. would know the best [img]images/icons/wink.gif[/img]
Old 05-02-2002, 08:52 AM
The measurement from the tiller of one engine to the other is 24.5". I was told it should be 26" and my transom height should be 30". ???? My transom center line is 30.5" I was told to cut my transom down to 30" and move engines to 26" centers. I do it in a heart beat if I was sure it was the cure...
