Old 05-27-2003, 09:11 PM
POUNCE POUNCE is offline
Default Re: 225 opti max
I have the same setup as dunc. I popped out one plug and it was a whole new boat. Did one more and she was Purrrfect!
Before I started taking out the plugs I was turning 5200 rpm WOT. Now I can turn 5500 - 5600 w/ no problem.
My mechanic says if you can't turn over 5400 you are over propped - I believe him.
[ May 27, 2003, 08:16 PM: Message edited by: POUNCE ]
Old 05-27-2003, 09:14 PM
size matters size matters is offline
Joe, I tried removing all three vevt holes at once , no luck my next step wil be smaller vent holes but I cant see where that is going to get me more top end speed . I talked to a dealer down in va. beach he told me his 23s with 225 optis are running 45 to 48 mph.thats about 12 mph faster than im getting Im starting to wonder if its the moter?with these new moters can you even tell if its running on five pistons? thanks for all the help guys.
dinger
Old 05-27-2003, 09:19 PM
I'm also getting a top end of 48 - Near Empty tank, no gear and prop way up.
Old 05-27-2003, 09:24 PM
pounce, I bought my seacraft at the same place as you. were they telling you that 34mph was your top speed ? or to remove the vent plugs ? tuna season is right around the corner Im getting a little nervous. thanks
dinger
Old 05-28-2003, 08:11 AM
barnacle barnacle is offline
You can try and raise the engine up one hole. If your doing alot of offshore running its best to keep the engine low on the transome. It will stay hooked up in bad seas. You do not want these engines overpropped. I would have your dealer check it over to make sure your running on all 6 cylinders.
Old 05-28-2003, 07:36 PM
No, In fact before I bought, I went for a test ride on a '99 w/ the identical setup and we were getting 47 with my wife and the salesman on the boat. No BSing to be had there. When did you buy your boat? I know the sales staff has turned over and the I was not impressed with the newer crowd.
Are you sure your speedo is reading in MPH (and not knots)? Also be sure you have all your cyls - on my second powerhead.
Old 05-28-2003, 07:38 PM
There's a guy down this way with a '99 (Johnson Powered) having problems getting the same problem with top end. He's posted a few times about his problem on the WMI board. Interesting.
Old 05-28-2003, 09:31 PM
pounce, I bought the boat in the fall of 2001 all new sales team , seem like good guys they just kept telling me the rps were in the range 5100 my gps is in miles per hour tops is 34 mph at 5100. trying to get her in this week to see if we can get it right,hope its not the head
dinger
Old 05-29-2003, 10:15 AM
Eric McNiff Eric McNiff is offline
POUNCE - did you say you are already on your second powerhead with the Opti? I just had a 225 Opti installed on my 23 and heard it start up last night. When it stated my first thought was that it was not running on all cyliners - the mechanic just said that was the way an Opti was supposed to sound....I am still skeptical.
Eric
My wife does not care for the 2 boat theory
Old 05-29-2003, 12:22 PM
Yup second powerhead - the first one had 700 hours on it when it started running rough. My mechanic checked it out and said that I had really bad scoring in #2 and #6, give him $25 to fedex some parts and he'd take care of the rest. Somehow he got merc to cover it dispite the fact that I was just out of warranty.
