Old 07-23-2003, 06:49 PM
bobnoxious bobnoxious is offline
Default twin engines on 23' CC
My 23'CC SeaCraft has a cut out in the center of the transom for a 25" motor. I have measured the transom height on either side for twin motors and it is 25". Can I mount twin engins on this type transom w/o cutting out to accommodate 20" motors or fill in the center cutout or will it take two 25" motors as is?
Old 07-23-2003, 07:08 PM
BARNABY55 BARNABY55 is offline
Default Re: twin engines on 23' CC
Don't know about all the details..Do Know your 23 handles better with a single
Ted
Old 07-24-2003, 10:50 AM
ScottM ScottM is offline
Dieter Sprockets
Take a look at my transom (Scott McLeod's 23 Sceptre). Does it look like that? If the center cutout measures 25", then the original transom would be 30". In a twin setup, you would use 25" motors. Do NOT cut the transom down for 20" twins, with all that weight you'd be taking water over the back. Replace the missing section and go with 25's.
Old 07-24-2003, 02:08 PM
Briguy Briguy is offline
Bob,
I had a single 225 Johnson on my '78 23 MA. I just had the cut out fiberglassed over and mounted my twin 130's 2 bolt holes up. The fit like a glove. The same when I replaced the Yam 130's with my 115 4 stroker suzi's. Just put a bracket on and solve the prob once and for all.
As for performance, I noticed no difference in the ride by going from a single to twins. I did however feel a noticible improvement in ride quality by adding the bracket to my twins.
Capt. Brian
Old 07-24-2003, 03:36 PM
John R John R is offline
I have 2 20" motors you could buy cheap to try out [img]images/icons/grin.gif[/img] ... My boat has twin 235s on it (yes, that I'm selling) and it's a flat 25" notch not a 30 transom cut in the center to 25. Also seems like you would have that extra cut getting in the way of mounting 25's around it...
Surf and Boat fishing for
Striped Bass
Old 07-26-2003, 01:07 AM
thanks to all for you comment and guidance. It seems to be easier and less expensive to remain w/ a single engine. There is a lot of work to be done to this boat, so I'll make a final decision this winter when I begin restoration in earnest. If I find rot in the transom, then I'll repair and mount twins.
bobnoxious in north carolina
Old 07-27-2003, 09:12 AM
Finster Finster is offline
Briguy, hows the preformance with the twin 115's? Is it enough?
I am now leaning toward twin 140's for my boat, but I want to be sure I get the preformance I want. (face stretched back and hair on fire) [img]images/icons/shocked.gif[/img]
No but seriously, my buddy has twin 140's on his Mako 25 and he seems happy enough, he say he cruses at 22 to 24 kts.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
