Old 01-02-2004, 10:43 PM
GC GC is offline
Default pop up cleats
I have a question for those who went the pop route with their cleats and bow light. Do you just substitute 2 new pop up cleats where the old ones we're along side the bow light,or fill the old holes and add 1 new cleat directly behind the light? It appears on the new 20' there are 2 stainless trim pieces along side the bow light and 1 cleat between them. Which way would you do it? Thanks
Old 01-02-2004, 10:54 PM
Default Re: pop up cleats
Fly20
I don't know about the 20' [img]images/icons/confused.gif[/img] I think you'll find it both ways but installation on my 23' I had to go the one pop-up in the center and the two trim pieces because the depth of the pop-ups would not allow placement to the outter edge without hitting the bow curve inside and then I couldn't attach the drain tubes [img]images/icons/frown.gif[/img]
http://www.theboatzone.com/gallery/CSteele/res8259
Old 01-02-2004, 11:22 PM
Ikan Besar Ikan Besar is offline
I had the two cleat version at one point on my 18' and replaced them with a single 6" pull-up in the middle: vast improvement.
Like Capt Chuck suggested, the flare would likely prevent using two pop-up or pull-up cleats that close to the edge. In addition, it is far less cluttered with just one centrally located.
On my 20' I will be going with the same layout as the new 20's, which means launching that original 3" high bow railing into the nearest recepticle.
Old 01-03-2004, 01:46 AM
Scott Scott is offline
Fly ....Not a 20 but .. Bow cleats on Seafari's 23'
Capt Chuck...The hatch on the casting platform ... Did you use a piano hinge?? how's it working out for you ?? and is that paint on the topside?? ....LOOKS GREAT !!!
[ January 03, 2004, 12:47 AM: Message edited by: Scott ]
Old 01-03-2004, 09:20 AM
Thanks Scott
That indeed is a piano hinge on the casting deck as well as the forward deck hold. (Factory installed) The decks and inner liner are all original gelcoat. It will be painted someday. Lot of battlescars [img]images/icons/frown.gif[/img]
The topside has been painted with Signature Finish & nonskid added. Hard to see in the pics. Works great, easy to apply & repair [img]images/icons/grin.gif[/img]
Old 01-03-2004, 10:37 AM
TUGBOAT TUGBOAT is offline
Hi Fly
Here's My 20 MA I chose the 1 cleat/lift(pull up) & pull up Chocks .Scream'n Reels [img]images/icons/cool.gif[/img] pull up cleats The Boat Zone
[ January 03, 2004, 09:40 AM: Message edited by: Capt. Brad ]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 01-03-2004, 11:10 AM
ScottM ScottM is offline
Dieter Sprockets
I think Capt Brad meant this...
http://www.theboatzone.com/gallery/C.../seacraft5_023
Hope to get me some of these in Dania! [img]images/icons/grin.gif[/img]
[ January 03, 2004, 10:12 AM: Message edited by: Scott ScottM ]
Old 01-03-2004, 10:44 PM
GC GC is offline
Thanks for the quick responses. Really like Capt. Brad's set up. Never would have thought of that. Capt. Chuck where did you find those trim pieces?Thanks again.
[ January 03, 2004, 09:47 PM: Message edited by: fly20 ]
Old 01-04-2004, 01:50 AM
ThanX Scott !! [img]images/icons/cool.gif[/img]
www.frenzie.com
Old 01-04-2004, 09:41 AM
Fly20
Boat US has the Stainless Steel Line chaffing in different lengths [img]images/icons/cool.gif[/img]
