Old 04-09-2004, 09:01 AM
NOAHSARK NOAHSARK is offline
Default WANTED LOWRANCE LCX 15MT GPS MODULE
I AM NEED OF THE GPS MODULE FOR A LOWRANCE LCX 15MT. THANKS IN ADVANCE.
GOD BLESS, TIGHT LINES!!
GOD BLESS, TIGHT LINES!!!
Old 04-09-2004, 11:55 PM
fishez4alivin fishez4alivin is offline
Default Re: WANTED LOWRANCE LCX 15MT GPS MODULE
i dont know if they would work, but i have one lowrance, and one eagle gps modules that i used for a global map 2000, the eagle is newer and the same exact shape and size of the lowrance, except for the decals, they are identical.
Old 04-12-2004, 03:56 PM
THANKS FOR THE REPLY, HOW MUCH ARE YOU LOOKING TO GET FOR THE LOWRANCE MODULE, ALSO DO YOU HAVE A PART # SOMEWHERE ON IT SO THAT I CAN DETERMINE IF IT WOULD WORK. THANKS IN ADVANCE.
Old 04-13-2004, 03:44 PM
one is a SeaNav 5 and the other says Lowrance GPS, both worked, I replaced the older one and when i went up to mount it, i found the old cable was broken at the base of the connector, didnt check it before because it looked fine. I guess you need to find out from lowrance if its compatible, it is the rectangular shaped module, not the round type like i have for my global map 3000MT. If its compatible, you can have either for 50 bucks, i paid 300 at west marine for the newer one 2 seasons ago.
