Old 08-23-2004, 10:57 PM
islandmon islandmon is offline
Default need some ideas - my brain is all worn out
I actually have given this a good bit of thought but most of my solutions are not simple and I thought I'd tap the collective pool of common sense and practical thinking I've been reading on the forum. If you want to help, please look at dash pictures on http://www.theboatzone.com/gallery/cs01?&page=6 and page 8
Old 08-23-2004, 11:00 PM
Default Re: need some ideas - my brain is all worn out
ran out of room - the area to post kept shrinking. Too many solvents inhaled yesterday!
Anyway - help. I need suggestions on something simple to fill the hole on the dash and a simple way to repair the area of the dash where the light is mounted right on top of the SeaCraft logo?
Old 08-24-2004, 09:49 AM
Billybob Billybob is offline
You could just cover it up with starboard and remount your gauges/switches. It's easy and cheap, looks pretty clean.
Old 08-24-2004, 10:31 PM
Now we're talking! Thanks Billy Bob. I like your idea - simple ans straightforward. What version of Lowrance machine is that you have mounted? How do you like it's performance?
Old 08-25-2004, 10:13 AM
That is an lcx-15mt, and I liked it.I just sold it though because I got a Garmin 2006C for Christmas.I love the Garmin's color and it has good mapping and the gsd20 sounder works great.It was a great gift but for 2 grand, I would have kept the Lowrance and got tabs or hyd steering.
Good luck.
Old 08-25-2004, 10:21 AM
To keep the woodgrain look, maybe a type of Formica? maybe overlayed and use the old one to drill the switch holes exact from the back.
Old 08-25-2004, 09:53 PM
You could always buy a thin piece of teak the size you need. The teal will look really classy, and doesn't cost that much more than starboard in small sizes. (Never, never have wood screws bite into teak you don't want to crack or split, use machine screws and nylock nuts.)
Fr. Frank says:
Currently without a SeaCraft
Old 08-26-2004, 07:04 AM
RS RS is offline
This is how my console is starting to lay out. I used 1/4 inch starboard to patch some smaller holes and placed the trim tab switches and accessory socket in them. The instrument panel is just plexi that I had lying around. I'm considering using teak veneer plywood for the final version.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 08-30-2004, 04:48 PM
I have been searching the synthetic teak sites. I'd love to keep the wood look, but without the teak maintenance.
Old 08-31-2004, 11:48 AM
gw204 gw204 is offline
Rowmark has some really neat engravable acrylic sheets. You can get solid colors, simulated wood (not sure if it's suitable for outdoor use though) or even simulated granite.
http://www.rowmark.com/secondary.asp...ls/default.asp
Using this would allow you to have the switch functions and the big SeaCraft logo engraved on the panel.
I've used this stuff before and it yields very nice results.
Good luck.
Brian
1981 Mako 17
