Old 10-21-2004, 04:27 PM
sogilmore sogilmore is offline
Default Re: test
Mark
Where is the photo of the other 20 restored to better than new? Like your project in scope anyway. It was finished off in the seacraft pale yellow, black boot stripe and they talked about the raised Seacraft decal as in what is used today.
I wanted to revisit that project.....and I can't remember where on the website it is.
Any help, anybody. Congrats to you both, both projects are the best I have ever seen.
-sean
Old 10-22-2004, 02:35 AM
rockdoc rockdoc is offline
Default Re: test
Sean,
you might be talking about Hammer's 20' boat- it's on the homepage at http://www.classicseacraft.com/hammers20CC.htm
Beautiful, and quite an inspiration.
Steve
Old 10-25-2004, 04:13 PM
Default Re: test
That's the one....thanks.
Well worth revisiting. Did that boat get awl-griped all over? I was told you should not use Awl-grip below the waterline? Any truth to this?
Hammer's 20 is another beautiful piece of work.
-sean
Old 11-06-2004, 09:29 AM
warthog5 warthog5 is offline
Default Re: test
2 days sitting in the water, you will be safe to Awlgrip the bottom. If you plan on it being in the water longer use bottom paint. Don't Awlgrip the bottom and then put bottom paint over it.
Excert from Fl Sportsman forum.
Dunk is a Marine Survayer
I've seen Awlgrip blister several times. About five years ago I surveying an older glass Trawler that had been Awlgriped from the cabin roof down. The boat was mint and had been bottom painted. When the was hauled the bottom looked like it had chicken pocks. The biggest blister was maybe the size of the dia of a pencil eraser, most were a 1/3 that size. At first sight I'm thinking some kind of weird gelcoat blistering, so I started popping a few of them where the bottom paint had come off the surface. What came off was paper thin and you could pop each one with your finger nail easily..and the gelcoat was fine under each. Then it dawned on me it was Awlgrip under the bottom paint. The boat being a 8-9kt boat didn't move fast enough to tear them off, but if it had been a 30-40mph boat it probably would have stripped most of the Awlgrip off there were so many of them. I mean we're talking 1000's of little blisters on a 28ft boat.. After I figured out what was going on and explained it to the buyer he bought the boat with a nice price reduction because of it. He told me a few weeks later that his marina stripped most of the Awlgrip off the bottom with a pressure washer right to the waterline. The rest came off with a little soda blasting. Fresh coat of bottom paint and the boat was fine..
Old 11-06-2004, 12:50 PM
optiguy optiguy is offline
Default Re: test
I find it hard to believe that using Awlgrip and similar paint systems underwater is bad. To me it is the surface prep that caused the problem. I have built over 60 boats in my life and many were painted top to bottom with similar paint systems. I have seen bad prep work cause blistering, but not the choice of paint.
Just my opinion.
Bill
