Old 05-26-2005, 11:06 AM
kwluis kwluis is offline
Default What would you guys do?
I just took delivery of a SC 23 with 225 opti.
The boat with 140 gal of gas and 2 people would only hit 5010 rpm max and just over 35 knots. The manual says that recommended full throttle range is 5000-5750 rpm and suggest that it runs WOT in the upper half of that range. The prop that the dealer put on there is the Mirage 17P. I am on the low end of the WOT rpm range that the manual suggests, I just don't know if that is good. I just can't go to the dealer and ask for a new prop either...they are located approximately 4 hours away.
My question for you guys is what would you do? Would you change the prop for an extra 700 or so rpm or just leave it alone? A new stainless prop is pricey and I am happy with the speed, performance and hole shot. I figured since they have sent out so many of these engines propped like this, that it would have the correct prop from the get go. Is the mirage 17P about the right prop? Is it possible that all I need to do is check the throttle adjustment in the engine? Is it bad for the engine though leaving it the way it is? Am I making the engine work harder? Am I taking the life away? I don't want to hurt the engine.
Thanks,
Luis
www.coolseasfishing.com
2005 Sea Craft 23
Old 05-26-2005, 11:37 AM
sailcat sailcat is offline
Default Re: What would you guys do?
Luis, One of the worst things you can do to an outboard is to lug it. Follow your owners manual. Dropping your pitch is going to give you a better hole shot, and the RPM that you gain will keep you if the same MPH range WOT. Call your dealer and express your concerns. Let them be responsible for your new motor.
Bob
72 20'CC
Old 05-26-2005, 12:01 PM
ocuyler ocuyler is offline
Luis,
Bob gives good advice. I would suggest you see what RPM you get with a 1/4 tank of fuel and one guy on board. Under those conditions, I'd like to see at least 5500 RPM at WOT. I think sheding almost 1000 pounds will give you that.
If that works out, I'd probably leave it alone. If the RPM is still low, I'd buy another to get up where you should be. I think it's always good policy to have a spare prop...
Otto
Old 05-26-2005, 12:17 PM
I’m with Otto on this one with the ¼ tank and one guy and trim it up as high as possible. If that doesn’t do it something is wrong. That Merc. of yours with a 17” should show around 5500 rpm’s. That’s the right prop. And 5500 is the right rpm’s.
Fellowship [img]/images/graemlins/cool.gif[/img]
Old 05-26-2005, 12:30 PM
Thanks for the input guys. I now have about 80 gallons in there...I will run her either today or tomorrow and see if there is any increase.
The only other things that I could figure for lack of RPM was either the engine was mounted too low (merc XXL shaft)or the throttle wasn't adjusted right. I'm going to play around with it a little and see what we find. Thanks again.
2005 Sea Craft 23
Old 05-26-2005, 12:38 PM
Abe's Rocket Abe's Rocket is offline
What kind of tach are you using? The tach itself could be off as well.
A Merc tech can plug directly into the motor while you are running and give an accurate RPM and then prop out based on that. But 35knots doesn't sound right with a 225.
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 05-26-2005, 04:24 PM
SCSeacraft SCSeacraft is offline
With the dealer that far away this may be a pain but raising the motor a hole or even 2 will give you more RPM and most definatly speed if the motor is too low.With the motor trimmed down does water spray up at a 45 degree angle from the foot? too low. A good prop shop can work 300 rpm's out of the prop you have and could have a good deal on a spare for you.
If the prop is a Mirage I would definatly get a spare nylon hub assembly and a prop wrench to keep on board.I learned the hard way after hitting a submurged log with mine a few weeks back.
Good luck and let us know how it goes.
Donnie
Old 05-27-2005, 08:57 AM
I have a merc tack on the console plus the smart craft digital display.
2005 Sea Craft 23
Old 05-27-2005, 09:13 AM
HatTrick HatTrick is offline
Boy it sure seems that this prop issue is pretty common. I just went through the same problem (not a huge problem certainly) and I think that dealers are really falling asleep on this one. Anyone repowering or buying a new boat is spending enough money to deserve the correct prop on the motor. When you go out to enjoy such a large investment the dealer shouldn't want you coming back to the dock shaking your head. If there are any dealers out there I would recommend:
1) Ask the customer if they want alum or SS.
2) Put the time into sea trials to identify the correct prop.
3) Since the customer is already dropping a bunch of money, offer a special price on an alum spare prop and prop wrench.
To those dealers already doing this I praise your attention to customer service, it's becoming a lost art.
'86 20 ft CC with 4-stroke 150 yamaha
Old 06-02-2005, 09:01 PM
Ok...I had the boat out the other day. Approximately 50 gallons of fuel, no fishing gear, and one other buddy. I had the engine trimmed up and the tabs trimmed...top RPM was 5200. I called the local Merc guy, but he was out this week having surgery. I am going to call him next week when he returns. I think the engine does need to be raised after looking at it. I will keep reporting in. Thanks for the advice.
2005 Sea Craft 23
