I am thinking of buying a pressure washer. I envision using it for a number of things, including washing the growth off my boat when i pull it out of the water.
What have been other people's experiences with pressure washers? I am interested in PSI ratings, specific manufacturers and the like. On other forums (see the below url) I have seen people talk about going as low as 1650 to 1750 PSI and still getting the job done. Thanks web page
http://i113.photobucket.com/albums/n...iseacraft3.jpg |
I used to have a deck refinishing business and I have one that goes up to 3000 psi. It will do just about any job I ask of it. It's just like buying a outboard.... get the biggest you can put on the boat. You can always turn down the psi if you want. I'd get one with a Honda or Briggs and Stratton engine. The rest of the parts are pretty generic once you get past the engine.
Like Strick, we have a Cat piston pump coupled to a Honda 9 HP, purchased from Northern Tool. It has 5 nozzles. There are 2 nozzles that are perfect for boat hulls, but you have to be careful not to blast off the bottom paint (unless you want too, because it will). Works great on non-slip too. There is one nozzle that's only purpose is to cut human flesh. We try to stay away from that one.
Gas is noisy compare to electric, but you can put this in the the back of the truck and make it work anywhere. We use a 500 gallon poly tank to give us over 2 hours of use on remote jobs. I also have a Karcher Electric Cold Water Pressure Washer . It works well cleaning up the boat, but is not strong enough for bottom jobs. There are several to choose from in between. If you rent or borrow a couple different ones, you'll know what you need. This is not an 80/20 rule decision. The pump, because it's adjustable in pressure, flow and RPM's (gas), you need one that will do the most difficult job you anticipate in any typical season. Northerners be sure to winterize them or don't let them freeze.
Otto And yes, I still believe in the four boat theory... |
Thanks for the great feedback. I was hoping to be able to settle for an electrical unit at around 1750 psi, but it sounds like you don't think that this will get the job done (such as getting growth off of the bottom of my boat). The last thing my wife wants to see is another gas engine in our shed & garage (let's see, snowblower, 2 mowers, leafblower, hedge trimmer, minibike & 15 hp kicker), but I want to purchase a product that meets my needs.
Go with a gas powered unit...the electric ones are good for wash downs
1986 Seacraft 23CC etec 250 Portland, Maine |
Peter, I owned a self service carwash in Daytona for 21
years. If you want a pump for serious duty make sure it is a Cat pump. They go for thousands of hours before any service is necessary. I purchased a 5hp Honda from Sams Club for $298, it has 2400lbs of pressure with 4 different tips. It has been great for all those little jobs around the house. Should last as long, if you take care of it. By the way it was manufactured by DeVilbiss. Which is a good company. Good Luck, Ken
See ya, Ken © |
I recently bought a Excell 2500 (also by DeVilbiss) at HD for $280 with a rebate for extra wand accessories - runs for 2 more weeks. It works real good and can clean the boat and everything else I've needed including chopping down Japanese Knockwood. I had a Kaercher 1650 last year and I wish I got the gas instead. The electric lacks the balls to do real cleaning. PLus being small, you can place it anywhere, like on the bow, which is great until you pull it off 'cause not paying attention [img]/images/graemlins/blush.gif[/img]
The gas is bulkier and heavier but worth it. PLus if your wife likes to clean outdoors, she'll like using it too.
Surf and Boat fishing for Striped Bass http://striped-bass.com/images/sb_small180b.gif |
I used on/off tonight on my boat and that got the crud stain off the boat, but did not budge the green growth & barnacles.
I then hooked up my new 4 hp Craftsman 2150PSI gas pressure washer. Wow!!!! It knocked all of the garbage off like nothing. What a tool. the only thing is that you have to be careful where you aim it. I have read that it will split cloth wide open, as well as skin. Cool tool, though
I ripped a seam on my Avon Inflatable last fall with my powerwasher...i love $300 mistakes...
Display Modes | |
