Old 07-22-2005, 11:43 AM
Default Fin - lookin good -
went with the drill, and hammer and chisel route, took me a couple hours to clean out the bottom pocket.
You got a ton o' holes there - was there a plate bolted on? Are you going to add a layer of glass to the inner transom, before or during the transom replace ?
Looks like you left the original drain tube in place - planning on leaving that in thru the transom replace, or just haven't pulled it out yet ? If leaving it in, did you leave any wood around it ?
Mine looks just about like yours at this stage.
Bill
Old 07-22-2005, 11:58 AM
Finster Finster is offline
Default Re: Fin - lookin good -
No all the threw hulls are out. And yes I'll put a few layers of glass on the inside and layer up 3/8 ply with a couple layers of matt in between each sheet.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 07-22-2005, 03:34 PM
Default Fin -
Looking close at that pic, I'm surprised how flat the inner transom is, given the wood condition -
my soggy transom resulted in some serious glass deformation at the lower engine bolt hole - they must have re-tightened the engine mount bolts every year, and put a squish into it. The upper holes aren't bad, but they were reinforced by the added thickness of the splashwell. Looks like I'm gong to have to reinforce the lower bolt hole area, and then level the inner transom, before I can go into new transom layup.
speaking of layups - you mentioned 3/8" ply ? What's your layup schedule going to be? cruising thru past threads, I've seen 1/4 luan, 3x 1/2 and 2x 3/4 ply - how much cured thickness do you get out of the glass layer your putting in there ?
thanks
Bill
Old 07-22-2005, 05:26 PM
Default Re: Fin -
You can really put in any conbination you want. The fact is, if you take mesurements around the cut, you'll find that it flucuates +- 3/16".
'76 23 SC CC I/O
Old 07-25-2005, 10:33 AM
stoney stoney is offline
Default Re: Finster - any more progress - pix ?
I did mine from the inside. I had over 50 holes in the transonm. The boat was originally dual outbourds. I had to do the deck cap also.
http://i15.photobucket.com/albums/a3...Picture001.jpg
http://i15.photobucket.com/albums/a3...Picture005.jpg
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 07-25-2005, 10:51 AM
Stoney
Looking at your pictures it appears your gas fill was on the starboard side. That's the first one I have seen [img]/images/graemlins/confused.gif[/img] What year is your hull?
Old 07-25-2005, 01:11 PM
The boat is registered as a 1971. The nameplate is embossed aluminum piece on the glovebox lid that is illegible.
Someone did some very poor quality repairs, and one of them was to move the gas fill to the starbord side.
They repaired the fiberglass hole in the deck cap and other broken spots on the deck cap with automobile body putty and window screening. I did replace the deck fill with a GEM product, which I believe you recommended and I am pleased thanks.
Old 07-25-2005, 09:32 PM
paulfurnari paulfurnari is offline
The splashwell is put together the same as mine which would make it a '72. This is also suppose to be the first year production of the 23' CC.
