Old 10-14-2005, 02:13 AM
Scott Scott is offline
Default Re: Rewiring
These are all warthogs pic's ...This last one won't post for some reason
last pic
Old 10-14-2005, 08:29 PM
i redid my whole boat year before last- from new dash and new gages and everything in between. I quit counting after about 600$ d think i ended up spending around a grand. i did the wm and bw buying deal. i ended up using a lot more black and red wire though cause buying spools for 6 ft of one color wire got too expensive in a hurry. good luck ! its really kinda fun and you will feel good about it after you finish!! [img]/images/graemlins/smile.gif[/img]
Old 10-15-2005, 01:21 AM
warthog5 warthog5 is offline
Another advantage to Best boat wire is they have 13 color's in their primary wire. Try to find that at a box store. You will be lucky to find 6 colors.
Old 10-15-2005, 02:47 AM
afernand afernand is offline
Miles Offshore: to me re-wiring seems to be a can of worms...but I am willing to try it...would you suggest a book or manual that I can learn from? -- Thanks, aaf
Old 10-15-2005, 12:12 PM
I have both of these + one more.
http://www.themotorbookstore.com/12-...for-boats.html
http://www.amazon.com/exec/obidos/tg...books&n=507846
Old 10-16-2005, 09:42 AM
warthog5 thanks for leads. -- aaf
Old 10-18-2005, 03:33 PM
Briguy Briguy is offline
Does anyone recommend the more expensive "tinned" wire.
Capt. Brian
Old 10-18-2005, 04:40 PM
Saltwater .... Yes! Below summs it up ;
web page
"The wire must be copper, but even copper corrodes in the marine environment, and corrosion is the primary cause of electrical failures on a boat. Plating each strand of the wire with a thin coat of tin-called tinning--dramatically improves corrosion resistance. The additional cost of tinned wire is nominal, the benefits substantial. Under normal circumstances use only tinned wire."
Old 10-18-2005, 05:43 PM
web page
Absolutely! [img]/images/graemlins/smile.gif[/img]
Old 10-18-2005, 06:42 PM
GOOD! That is what I have been using lately. It only costs a few cents more a foot and I get it for a reasonable price at Marine Surplus here in Sarasota.
Capt. Brian
