Old 04-19-2006, 11:07 AM
jongolds jongolds is offline
Default Nav Lights
The bow lights on my Tsunami are the wrong type. They're supposed to be mounted on the hull side and are mounted on the topside so the illuminated arc points to the sky instead of to the sides. Since I need to replace them, I'd like to switch to LED but don't think the look of the innovative lighting lamps would match my 73 Tsunami. Any one have any suggestions for an LED fixture with a more traditional look?
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 04-19-2006, 06:55 PM
Ntrain2k Ntrain2k is offline
Default Re: Nav Lights
You could find a traditional light that you like and then retrofit it with LED bulbs.
Old 04-19-2006, 08:53 PM
Bryan A. Bryan A. is offline
I got this link from Warthog. It seems you can retrofit almost anything to LED with those guys.
http://www.superbrightleds.com/cgi-b...=4720631.22545
I changed my navlights to these, I don't know if they will fit your application but I like them better than the Perko's that were there. The good thing is they are relativley inexpensive. I have not got the LED upgrade yet.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 04-20-2006, 11:43 AM
This is more or less what I have
http://lewismarine.com/images/products/9/955G_1.jpg
I'd love to get something similar with the LED. That link looks like the perfect solution assuming they'll fit in the fixture and are bright enough. You'd just get the white LEDS thought right. I would think putting the red & green behind red and green tinted lenses would be dim. I wonder if they'd be bright enough to be legal.
Norwalk, CT
Old 04-20-2006, 08:59 PM
warthog5 warthog5 is offline
Yes just get the White one's. If I remember right they make a Red, but no Green in that style.
Hmmmm! They do make a Green now.
I used the 1142-W19 White LED bulb [narrow bulb]
I have the LED's in my boat. They are pretty bright.
Old 04-23-2006, 08:23 PM
I just ordered the fixtures. I probably won't bother going with the LED bulbs at this point. I still don't have a proper stern light so won't be running much at night this season. It'll be on the list for this winter though.
Norwalk, CT
