  #161
Old 07-01-2006, 11:51 PM
Bryan A. Bryan A. is offline
Default Re: Finally Paint Time....
Nice job. Did you just tint regular epoxy or use a special epoxy bariercoat paint? And what did you tint it with? I have never seen that done before but it makes alot of sense. Keep up the good work.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 07-02-2006, 01:42 AM
Fishjack Fishjack is offline
Thanks for the comments guys. Here is what we accomplished today…
New SeaStar system -
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
Old 07-04-2006, 01:50 AM
Default Bracket and Motor ON might test run tomorrow...
I have worked all day into the night the last 3 days.. have some more wiring to do but hope to test run tomorrow...
Got the bracket and engine back on yesterday.. re-wired the motor today.. Installed the new SeaStar system. Mounted the bilge pumps.. B-60.. water pickup.. and a lot of other misc items. Hope to get a chance to run her late tomorrow.
Here are a few more pics -
I have been way to busy to take more pics but will take more of the inside tomorrow.
1977 23' Superfish
ST250x Yam
Old 07-05-2006, 09:49 PM
Default Splashed!!!!!!!
Well finished the transom - ran new bilge hoses and wiring, mounted all equipment in the transom area (oil tank, trim tab HPU, fuel filter, flow sensor, installed (+) and (-) buss bars and other items) in the large hatch on the transom bulkhead.
Still have to finish painting the deck from about the console up but wanted to get it back in the water. Still have to mount the 3 new rod holders across the back of the transom, re-install the two removed off the cap and finish dressing cables/hoses etc.
But anyway here she sits in the water - the Yam fired right up and ran great.
Mounted the new leaning post I bought from BA17 - thanks Brian it's great!!!
The stearn sits higher in the water than before. I was afraid that it would be heavier but seems like that is not the case. I only put 70 gallons of fuel on her for the test run.
Did I mention the transom is SOLID AS A ROCK
What a difference the new space in the cockpit area makes. Can't wait to bloody her up.
Thanks to everyone for the help along the way..
Will post more pics soon - action shots and more details of the newly laid out bilge area etc..
One thing that is strange - I remounted the transom bracket in exactly the same spot. Now the motor cavitates and I cannot get as much trim out of it??
While someone else was running the boat I stood on the bracket and the cavitation plate is about 1 inch above the surface of the water?? I guess the transom was flexing so much before with the thrust of the motor that it was forcing the engine down to the proper running angle??
I am going to drop the engine one bolt hole and see if that helps.
Anyone else experience this?
1977 23' Superfish
ST250x Yam
Old 07-05-2006, 10:08 PM
peterb peterb is offline
Default Re: Splashed!!!!!!!
Jack,
It looks fantastic. Wow!!!
Peter
Old 07-05-2006, 10:39 PM
Old 07-06-2006, 08:05 AM
fishjack,
all this work on ur boat makes me almost ready to cut into my 20 and put a new transom... made it look easy..
-evan
Old 07-06-2006, 08:14 AM
lost2a6 lost2a6 is offline
Way to go, looks good Jack, I can't wait to see it in person.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 07-06-2006, 11:50 AM
warthog5 warthog5 is offline
Glad to see this Jack.
What hole from the top is the motor mounted in now?
Sound's like your on the right track.
Old 07-06-2006, 12:34 PM
Thanks for the compliments guys – still have a bunch of work to do. Next major undertaking will be removing the cap, re-core/repaint, new S.S. rubrail and mount all flush/recessed hardware/lights. That will be sometime in the winter. I have missed enough fishing this summer to start that now. AND epoxy is no fun to work with in 90+ degree heat..
Warthog – I have one hole left at the top of the engine bracket so it should drop about 1 inch. I know the standard is 1 inch up for every 1 foot back as far as brackets go.
I sure hope that does it. I never had any problems with the prop blowing out (aeration) before but now in turns and when trimmed up even the slightest amount it aerates.
The ONLY other change was mounting the B-60 xducer and a water pickup but they are well to the sides of keel.
Will try and drop the motor tonight and test run this weekend.
1977 23' Superfish
ST250x Yam
