Old 09-13-2006, 08:51 PM
catspaw catspaw is offline
Default Scupper renewal
I have a '74 23' cc, it still has the orginal brass scupper tubes between the deck and the hull. What's the best repair for these and where do you get them? Thanks in advance.
Old 09-14-2006, 10:32 AM
Default Re: Scupper renewal
Hey, catspaw - Welcome to CSC !
If you're looking to replace them with brass tubes, 1" size, I've seen a number of references to Boston Whaler using the same tubes, and better BW dealers having them available as replacement parts. The thru deck scupper tubes are much longer than the typical 3" transom drain tubes you will find at most boat shops.
Bill
Old 09-14-2006, 08:31 PM
The brass tubing can be ordered from McMaster Carr for cheap (old Whaler fix)!! The brass tubing must be annealed before "flanging". Heat it cherry red and quench in water to anneal (or soften). If it were my SeaCraft, I would want the deck to drain out the transom. IMHO, that was the reason the boats got the bad name of "sinkcraft".......the tube and/or hose failed.
Old 09-16-2006, 06:51 AM
EagleOCNJ EagleOCNJ is offline
Anyone know of a post descibing how to convert to a transom scupper? Im ready to do it this winter!
