Old 10-05-2006, 04:58 PM
71kidcasper 71kidcasper is offline
Default 1708 on deck
I'm using 1/2" marine plywood on my new deck and I'm planning on glassing both sides before I install it. Do you guys think 1708 on both sides is overkill? I'm just concerned with the weight. Trying to keep it light, but I want to make sure she is plenty strong and will outlast me.
If it isn't deer season I'd rather be in a SEACRAFT
Old 10-06-2006, 12:48 AM
Default Re: 1708 on deck
Thats not overkill however you might want to use some matt as well on the top surface as the diagonal of the 1708 may bleed thru on your finished floor. What were you planning on for the walking surface of your floor? some people just epoxy the underside surface of the floor which is better then nothing. I prefer a light layer of glass.
Old 10-06-2006, 06:12 AM
warthog5 warthog5 is offline
Here's the thing about adding glass to Fir plywood unstead of just a couple of coat's of epoxy.
Fir plywood is what you would generaly buy as Marine plywood.
It's also lighter than Pine plywood.
If you don't add the glass the wood will still check and open up.
I have a long term experiment project that proves this well.
It doesn't take much glass. 4oz cloth will stop it.
Old 10-06-2006, 06:14 PM
Strick, When you say the walking surface on my floor are you refering to the glass or the nonskid? I'm planning on a layer of 1708,I'll take your advise on the print through, and a layer of 1 1/2 oz. matt. As for the nonskid I will most likely add it in the paint, although I've been thinking of putting some in the last coat of epoxy. I have done this on commercial boats in the past and it helps the nonskid from being worn away. I'm just not sure if the viscosity of the epoxy will consume most of the nonskid. I would like to have a fine texture to make comfortable on bare feet.
Old 10-06-2006, 11:36 PM
yea thats what I was talking about. You answered my question.
Old 10-07-2006, 09:53 PM
Anyone used rhino lining or any of the other liner material on their floor yet? I know it yellows but im going to be diving and deep dropping. That 5-10 # lead weight and the tanks banging around on the deck the little extra protection sounded pretty good.
RUSTY PARKER
Old 10-08-2006, 01:51 PM
There a quite a few folks that have sucessfully used Line-x.
http://continuouswave.com/ubb/Forum3/HTML/009702.html
Old 10-08-2006, 06:56 PM
That looks way better than i was planning on i was gonna spray everthing in the floor but the exposed deck around the hatches looks very good.
thanks for the pic and the reply
RUSTY
RUSTY PARKER
Old 10-08-2006, 08:38 PM
It's all in the detail's Rusty.
I'm a big fan of 3 toned boat's. Hull,inside & Nonskid being diffrent color's that complement each other.
Old 10-13-2006, 08:15 PM
I have the bottom of my deck coated with a layer of 1708. Does anyone think it makes a difference if i glass the top of the deck with 1708 and 1 1/2 oz. matt before I install the deck in the boat. Then I would tape the perimeter with a couple of layers of matt, or would it be better to glass the top after the deck is installed. I plan to bond the deck to the stringers and the flange of the orignal deck with epoxy and cabosil. I don't intend to use any mechanical fasteners, as i haven't used them any where yet.
