Old 10-31-2006, 12:31 AM
Default Re: tubes for deck drains
reel
if the stuff u have is 1" in diameter ill take it. ill PM u for shipping.
Old 10-31-2006, 05:12 PM
abl1111 abl1111 is offline
I have seen some really nice work on this site w/ PVC set in epoxy. I re-did my 'tubes' (3) years ago and if I were to do it again I would do it the epoxy/PVC way.
Old 10-31-2006, 09:55 PM
i would do that but i havent found any drain plugs that fit inside the pvc tubes.
Old 11-02-2006, 06:27 PM
Hmmm. Never thought about that. What is the inside diam. for a PVC tube that you might use ? Maybe it could be bored out to fit the available plugs by a machine shop for a few bucks ??
Old 11-02-2006, 07:37 PM
i used a piece of sprinkler pvc riser from home depot. i didnt do that great of a job on it so im a little dissapointed in myslelf. i have to do it again though because it still has a slow leak somewhere around that drain into the bilge.
Old 11-03-2006, 11:08 AM
RS RS is offline
The standard 1" bailer plug should fit into 1" sch 40 pvc. If you used 3/4 sch40, the ID is .81". You can wrap a few layers of tommy tape around a 5/8" bailer plug.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 11-03-2006, 05:58 PM
what is tommy tape?
Old 11-03-2006, 10:55 PM
I cannot believe you just mentioned " Tommy Tape " !!!! I had been trying to remember what that tape is called - I have tried to describe it to several good hardware stores, with out knowing the name, and they looked at me like I was crazy.
THANK YOU !
Old 11-04-2006, 12:39 AM
teflon tape??
Old 11-04-2006, 01:45 AM
RS RS is offline
what is tommy tape?
Self fusing silicone tape. It stretches so it can be used on an expanding plug. I've used it on a 1" plug to use in a 1 1/4 drain hole.
Best regards,
Roger
