Old 04-19-2007, 08:51 PM
abl1111 abl1111 is offline
Default Ablative bottom paint question
I have Petit Trinidad "SR" Ablative paint on my hull. Is it adequate to rough up entire hull w/ a 3M abrasive pad and just paint bare spots with new paint, as opposed to painting the entire hull ?
THX
Old 04-19-2007, 09:02 PM
peterb peterb is offline
Default Re: Ablative bottom paint question
Isn't that what they advertize?
Old 04-19-2007, 09:57 PM
By "abrasive pad" I presume you mean Scotch Brite? Yes, that will work.
Fr. Frank says:
Currently without a SeaCraft
Old 04-19-2007, 10:19 PM
joseeli8797 joseeli8797 is offline
Be careful when sanding, use good repritory protection I have to drink Benadril after I work with bottom paint it realy breaks me out. Jose
www.fiberglassman.com
Old 04-20-2007, 09:49 AM
Sounds good. With the price of this stuff a gallon, $225, I'll try to make it stretch a bit.
Old 04-20-2007, 07:01 PM
BigLew BigLew is offline
Just a suggestion.
Put an entire coat of paint on that is a different color. When it wears thru the undercoat will be evident and where the wear spots are will be obvious. Just a suggestion.
Good luck and cover up and wear a good mask; A-F paint is nasty stuff in your air passages. Loaded with Cuporous Oxide- read that POISON!!!!!
Plan accordingly!
Old 04-20-2007, 09:19 PM
Thx already done - the previous owner had it painted red, I have it black. Thx all.
Old 04-21-2007, 09:48 AM
Bryan A. Bryan A. is offline
I have Micron Extra on my boat and I found if I wetsand with 3M paper and a garden hose it keeps the dust way down, almost non existant. If you don't mind getting wet and doing it on a warm day it works well for spot applications which is where I am at now with the Whitewater. Down side is you do it by hand if you don't have a fancy air powered wet sander which I don't. I usually buy a quart a year and touch up spots. I put one coat of blue and two of Shark white the first time around. Try it out.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
