Old 06-24-2007, 12:00 PM
CarlaDee CarlaDee is offline
Default Blew Up the 225 Opti - New Power for 23 Sceptre
My Opti finally let go... about 1500 hours.
Please give me thoughts... I am going to pull the trigger hopefully this week.
1. Suzuki 300
2. Opti 300
3. Suzuki 250
4. Opti 250
5. Honda 225 (I can get this for $14k)
Also considering a bracket, but I have been told by a few folks that this may worsen my ride. Boat rides great now, so I don't want to do that.
Please chime in!
Daniel
Old 06-24-2007, 04:01 PM
Default Re: Blew Up the 225 Opti - New Power for 23 Sceptre
I have a 225 2 stroke Yamaha on my 23’ CC and it runs just fine like your 225 Merc. must have done on yours as well. I still have a lot of time left on my Yamaha but if I was going to replace I would just go up to 250 not a 300. I really don’t see any advantages in going up to 300 hp. I would probably do the E Tech. because of it’s weight. I also have the motor on the transom and like it that way, but a lot of guys love it on a bracket and say they ride even better “like a 25 footer” with one. If I were to go with a 300 I would have the bracket because of the extra weight.
FellowShip
__________________________________________________ ________
Just for the Grins
Old 06-24-2007, 07:45 PM
My '73 23' has alum. bracket and 250 Yam. OX66. I'm not sure it's dialed in "just" right but, I would like more HP.....If/When I re-power I will look at singles (to keep the same bracket)...300 Suzi. or e-tec maybe 250...or....go twin 150-200's and have to change bracket. Sure would be nice to drive some that are powered differently...sounds like a raft-up to me!!
Old 06-24-2007, 08:04 PM
joema joema is offline
happy with df250 on scepter weight no problem but i put a30 inch transom on her boat seams well balanced and love the quite idle
Old 06-24-2007, 08:06 PM
Thanks for the comments. Hopefully I will get a few more. I am really considering the Opti 225/250/300 and the Suzuki 250/300. All of the Opti's will weigh the same - just over 500lbs. The Suzukis will weigh right at 600lbs. I don't think that the extra 100lbs will be a big issue, but, if it was, I guess I could always add the bracket and rehang the motor? Not ideal, but I guess it would work.
For what it is worth, I have stood on the 225 Opti and it does not make a significant change in the water line.
Keep the comments coming! I hope to buy an engine in the next few days!
Old 06-24-2007, 08:11 PM
joe - just sent you a pm. any additional details would be much appreciated. thanks for the help.
Old 06-24-2007, 09:23 PM
The E-TEC is definitely worth a look; low weight & fuel consumption like the Opti, but MUCH quieter, about same as 4-stroke, but also much less maintenence than the 4S. Everyone I've met that has one has had only good things to say about them. BRP is also sandbagging on the HP rating, at least on some models. The 150 is really about 165, and the 225 is actually a 240!
Old 06-24-2007, 10:16 PM
oz775 oz775 is offline
I am extremley happy with my 225 Opti- boat runs like a raped ape!!! Was looking at engines the same way you are and got a deal on the Opti that I could not turn down that included a 5 yr warranty, 30 inch shaft, and DTS controls. All the other engines were around 20k with controls, installation, etc. Engine gets great gas milege and I have never seen a puff of smoke from it. Would buy another Opti in a NY second!!
1974 Tsunami- 2004 Merc 225 Opti on bracket
Old 06-24-2007, 11:46 PM
Fishjack Fishjack is offline
If (knock on wood) something major was to happen to my Yamaha 250HP OX-66 I am 99% sure I would go with the E-tec.
"Rumor" has it that they are about to release a 275hp or bigger E-tec.. Same weight (block) as the 250 with a few tweaks.. time will tell.
Best of luck.
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
Old 06-25-2007, 02:43 AM
Call Hermco and have him put a twin engine seamark fiberglass bracket on your boat. Buy a suzuki 300HP 30 inch shaft and then you will have the ultimate Seacraft.
Strick
