Old 07-05-2007, 06:52 PM
askipper3 askipper3 is offline
Default 84' 20SF WET BOAT PROBLEM.....
Ive been fishing in my 84' 20SF and it has a scuppers oneach side, and 2 in the middle, by the engine.
The ones on the sides....(specially the starboard side beacse it has a 70lb battery back there) water comes in, in excessive amounts when you get back there.
What is a good solution, not plugs, to keep water out.....but not in.
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150
http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg
Old 07-05-2007, 06:59 PM
Default Re: 84' 20SF WET BOAT PROBLEM.....
askipper3-Move the battery and and fuel tank farther forward and raise the deck, or just try ball scuppers. My 18 did that with the battery(s) in the console and a 358Lb lightweight 2 stroke. Have you talked to Ikan?
Old 07-05-2007, 09:47 PM
At least get the batt out of there
Old 07-05-2007, 09:57 PM
Rabud makes a ping pong ball scupper.
Water goes out, but does not come in.
Click on products tab, look down 3 rows on the far right.
Rabud
See ya, Ken
Old 07-05-2007, 11:23 PM
Rich Rich is offline
Or you could try FELLOW-SHIP'S double top secret "VORTEX"!!
VORTEX
Reading that post again made me LOL! Not from the VORTEX itself, but from all the responses...
The VORTEX kicks ass!!
Cape Marine Supply
Old 07-06-2007, 10:05 AM
PressureDrop PressureDrop is offline
I recently installed the Rabuds on my seafari and i would say they work 75% of the time, the problem is sometimes the ball gets forced up and water just streams in, im going to see if i can glue something in it to prevent that from happening but i might just go back to the old school check valves, all in all, not very impressed with the rabuds.
no falls, no balls
Old 07-06-2007, 01:41 PM
red20 red20 is offline
After moving the Bat forward try keeping the in-deck well dry. less water weight in the hull.
Old 07-06-2007, 05:26 PM
Really no choice, but to keep the battery in there. I run two, one is under the console, and one plauges me in the back.
I will get the water out of the in-well tank. I cant seem to find a plug that fits the hole tho.
Also, I'll try the rabuds. what do they run for>
Old 07-06-2007, 05:28 PM
Nope havnt talked to Ikan. The solution to me sounds like move the battery and put in ball scuppers.
Old 07-06-2007, 09:32 PM
i had both bats under my console on my '84? also had factory stainless steel flappers on the scuppers. they worked pretty good keeping the water out. they were heavy enough to stay closed while at rest but the force of the water when under way was strong enough to drain out. I did make a slight mod to change the angle on the flappers. I fab'd up a shim to put a better angle on the flapper to make sure they were shut when not under way.
