Old 09-30-2007, 12:13 PM
Default `96 ocean pro rough off idle - 1800rpm
Howdy,
I bought an `89 20 sf with a `96 ocean pro 150. Compression is 90 across the board. Not 89, not 91. It sat for a while. The owner thought it was over propped as it wouldn`t turn more than 4500wot. I thought it was a carb/ fuel issue. I had the motor baselined by George at G&S locally. Carb job, switch out oil pump for premix, new water pump, and seals.
He said that motor was a perfect match for the hull and should turn 5600 wot easy. I ran fuel conditioner and then ring free/ techron at shock level of 1 oz for 2 gals for 40 gals fresh fuel. I have put 80 hrs on it and now turn 51-5200 wot w 50 gals fuel , 3 average guys and a bimini. The hull and deck are solid w/ no intrusion anywhere. Boat does not ride low. Motor sings after hitting 1800.
Thx,
Sandman
Old 09-30-2007, 01:58 PM
Default Re: `96 ocean pro rough off idle - 1800rpm
Have you changed the plugs? If not that's the first thing I would do. Those have the OSI ignition which is tricky. If you ever get random stalling issue . . . then replace the powerpacks Also check ebay for 17P Viper . . . that should get your RPM up.
Old 09-30-2007, 07:00 PM
Hi BigShrinpin,
New plugs and tune up , I`m turning a Michigan 14 1/2 x 17 stainless prop in excellent condition. I`m gonna go alone bimini down and trim up to see what I hit. I dont have tabs yet and will need some. Hint Hint to all.
Art at bombardier tech support said it could be overpropped as he`s seen that. Does a Viper have less cup? She sings after 1800.
Thx,
Sandman
Those who say the best day of their miserable life was when they sold their boat never owned a Seacraft.
Old 10-01-2007, 01:29 AM
If you have the michigan rapture stainless prop . . . DUMP IT.
It's the WORST prop for a 20 seacraft. Do a search on the site and see some of my old post about my brand new 17p Michigan Rapture prop.
Old 10-01-2007, 01:43 AM
Check out Propgods.com . . .
http://www.propgods.com/content/about_us.aspx
My favorite two seacraft props are the Mirage "Plus" and the Highfive. There's an hub kit (from Merc) that will allow your motor to run the MERC props.
PROPGODS.COM - About Our Company
Prop Gods LLC was started by Jody Carter and Ken Reeves in Sarasota Prop Gods, is a mobile prop testing service, and prop retailer. We will provide you with the best service available and help you choose the best prop for your needs. We offer a wide variety of mercury SS props for you to test at a location of your choice in the area..
In our opinion, Mercury is the leader in prop technology and has a wide variety of props available for a variety of engine manufacturers. We have been involved in boating for many years and found prop selection to be one of the most important choices for your boat.
Old 10-01-2007, 09:40 AM
Thanks Big Shrimpin,
It seems like a real crapshoot finding the right prop. I`ll check your posts
Sandman
Old 10-15-2007, 10:20 PM
Can you raise the motor some? they like that alot
