Old 02-21-2008, 06:39 PM
tbone tbone is offline
Default Twins on a 1978 23ft center console
I have a rebuilt 23 and was curious if anyone knows if twin 140's suzukis will be to much weight.
Old 02-24-2008, 08:17 AM
Default Re: Twins on a 1978 23ft center console
I have a 23 with a single 225 on the transom. If I ever went with twins I would close off the transom and add a good flotation bracket. The 23’s with twins while drift fishing like everyone does in Key West would cause water over the stern with your wind conditions lets say from 3-5 & 4-6’.
FellowShip
__________________________________________________ ________
Just for the Grins
Old 02-25-2008, 09:27 PM
dsherod dsherod is offline
I have a 23 with twin 120's and have seen yamaha 130's, but I think the zuks are heavier. My 120s are about 300# each, if that helps.
I once thought I was wrong, but I later learned that I was mistaken.
Old 02-25-2008, 11:05 PM
Briguy Briguy is offline
Tbone,
You didn't mention if you have a CC or cabin model. The cabin model would take the weight. I have a 1978 CC that has twin 115 suzuki 4 strokes. They were mounted on the transom and were slightly heavy. I now have a braket, enclosed transom and also went from an 8ft 150 gallon fuel tank to a 5 1/2 foot 100 gallon tank which moved some weight forward. The boat sits nicely and won't take on water though the scuppers unless you stand in the back corner. I just use plugs in the scupper holes. The twin 140's will sit low and overall i would recommend just going with a 250 or 300 suzuki. If I were to repower I'd get a 300 Suzi. It weighs mid to low 600's while my 115's tip the scales at 416 each.
Performance wise I get 25.5kts(10 gph) at 4000 and 39kts at 5950 spinning 23" ss props, non CR. The 140's would probably pick up 2kts.
Capt. Brian
Old 02-27-2008, 10:35 AM
76Savage 76Savage is offline
Just put twin 150 Yahama 4 strokes on 76 Savage with bracket. Top end 49 mhp with 2.7 gph at 28 mph. The bracket is a must with that much weight on the back.
Sea the Craft -- Be the Craft
Old 02-27-2008, 01:01 PM
peterb peterb is offline
Good question
I have twin 200 OX66's on my 1972 23 footer.
It all comes down to weight.
What is th weight that you are looking at?
Old 02-27-2008, 01:52 PM
Good question
I can vouch that twin 200's on a 23 is a beast! That thing is a ROCKET!!!!!!!!!!!!!
Capt. Brian
Old 02-27-2008, 02:08 PM
SeaMaster SeaMaster is offline
tbone, we live in key west and have a completly restored 79 cc 23. We have twin 150's. We crusie at around 34 mph loaded. If you have any questions just let me know. Do you have a seacraft alreayd, and where are you located in kw?
http://img.photobucket.com/albums/v7...6/582ba35a.jpg
1979 23 cc SeaCraft twin Yamaha 200 HPDI's
1999 16 Carolina Skiff
2006 4x4 Titan
Old 02-27-2008, 08:06 PM
turfin turfin is offline
I have a1978 23 cc with twin175 johnson's they are fine the boat will run around 50mph and they are ok on the transom maybe a little heavy but it is worth it
