Old 02-27-2008, 10:30 AM
Default What I did to remove.
My second piece of wood was a bear to remove. What I did was make vertical and horizontal cuts with a circular saw down to the skin.(try 12*12 size first,and adjust from there) Then I used a wood chisel and pry bar and it came out a lot easier. It seems that a big piece has more leverage, so its harder to budge.
Unless the guys that have gone here before say different: I would not cut the outer skin off.
Old 02-27-2008, 11:09 AM
WillyC WillyC is offline
Default Re: What I did to remove.
The circular saw and wood chisel will work well. I also suggest getting a good grinder with 24 or 36 grit discs. I would definitely try to leave the outer skin intact.
Old 02-27-2008, 01:00 PM
skipjake04 skipjake04 is offline
thanks. I used the saw on the first few layers, but sure get nervous when it gets this thin. I guess a few slips is easier than the whole thing. a claw hammer was working well on the first few layers also until I swung in though my pinky. I took the rest of the night off.
headed to the store now for the grinder pads/disc.
thanks for the input.
SkipJake
1972 20 S.F , merc 97 150 offshore
Old 02-27-2008, 06:04 PM
hermco hermco is offline
Why?
Old 03-04-2008, 12:32 AM
the 'copy-catting" continues, thanks again to all for the great information and pictures to follow.
couple of questions.
1. can I use 1/2 inch plywood for the deck some have used it and other not. Is it a matter of opinion.
2. I am obviously raising the deck and am going to attach to existing gunnels. If they are supported and glassed in do I need to worry about flex? could I back fill with foam? Here is where I am at now. Weather has been wet so I couldn't start on transom. Hopefully tomorrow
SkipJake
Old 03-04-2008, 09:49 AM
Default Floor?
This is just fact...My 21 had 1/2 inch ply,and was still good after 40 years. In replacing the floor, I will go with 1/2 inch. (The reason I am replacing the floor is that the non skid from the factory was so shot it was easier to remove than fix)
Old 03-04-2008, 10:22 AM
Default Re: Floor?
that's mine also. I was going to try and reuse the original floor and I guess it could be salvaged, but I don't want to still be working on it in four months.
Thanks
SkipJake
Old 03-10-2008, 12:08 AM
Default Re: Floor?
transom finally cut
test fit. It worked the first time can't believe it.
my helper and side shot of "new" console
SkipJake
Old 03-10-2008, 10:59 AM
1/2 inch is fine just glass the top and bottom and it will last as long as you are alive to use it. If you are thinking of your kids grand kids down the road then use composite. As far as flex goes..... I would not be too concerned because the original set up was built to flex and you are glassing it together pretty much the same way you took it apart.
Old 04-13-2008, 07:09 PM
transom work.
just need to lay inner skin
outside shot
one more shot
SkipJake
