Old 04-03-2008, 02:39 AM
manuelfadra manuelfadra is offline
Default Speed on 23 seacraft
I have a 23 SC with twin 200 Yamaha on transom I purcased this boat as a project that came up very very nice we installed new tank, deck and transon is like new. last Sunday was my second ride on this boat. I think that the engines are a litter lower than what they should be because with the twin 200HP the top speed is 52-53 miles at full trim 5400 rpm with 19 mirages and the problem that I have is that I can’t go higher on the engine. Do you thing I will spend more fuel with the engines like that?
This kind of boat is not an speed boat I thing that a soft ride on the SC 23 is around 35-40 MPH
Should I install a bracket? or should I leave it like that at 3500 rpm Speed is arround 33-34 mph and the engine sound relax at that speed
What is the nominal Speed for a 23 SC i mean nice ride? (your opinion)
I would like to know if the stringers for a 23 seacraft were build with wood or foam year 1987
Thanks
Old 04-03-2008, 08:40 AM
Tarpun Tarpun is offline
Default Re: Speed on 23 seacraft
Welcome to the site. The stringers are foam filled fiberglass. As for the speed it seems a little low but I'm no expert. Load will affect speed, so will t-tops. Tight lines.
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 04-03-2008, 09:10 AM
peterb peterb is offline
I have the same setup (twin 200 Yamaha's)on a full flotation bracket. I can get them up to about 57 MPH. I am running 21 x 14 3/4 prop's. I also, have 19 x 15 1/4 props. I will give them another try as I just had the engiens lowered one notch (last summer I raised them two notches, one notch too high).
At cruise (30 MPH to 40 MPH) I get around 1.7 miles per gallon. These are 0X66 engines. If I had HPDI's I suspect that I would get around 2 miles per gallon.
Old 04-03-2008, 11:40 AM
Peter were did you get your bracket and for how much do you think i can get one (full flotation)
Old 04-03-2008, 02:18 PM
Mine came with my boat.
You could buy one new (Hermco/Potter, Armstrong or someone else) or used.
Here is a used one on ebay
web page
Some of our more talented CSC owners have built their own. If you do a search on this web site, you should see some exellent examples.
Also, if you did put a bracket you can then also enclose the transom (which is another very nice thing to have).
Good luck.
Peter
PS Do you have trim tabs with your current setup?
Old 04-03-2008, 06:55 PM
yes i have trim tab let see if i find the way to attach some pic of the SC so you can take a look at it
Old 04-04-2008, 10:20 AM
Osmany,
What port do you hail out of?
Peter
Old 04-04-2008, 12:23 PM
Miami FL
Old 04-04-2008, 10:23 PM
Well, you are in the best place in the country, in terms of parts and the like (especailly for SeaCrafts).
Are you really thinking of putting on a bracket? if so, will you buy new or used? Also, would you do it yourself or have someone else do it.
Also, would you close the transom at the same time?
On your current setup what is the mininum speed at which you can plane?
Peter
Old 04-07-2008, 03:23 PM
Ok Peter you know twin 200 is a lot of power for the sc 23 I think that my boat plane at 14.5 MPH
About putting a bracket I would love to but depend how much more I will have to spend because I already spend more that what I was thinking and I would like to get a used bracket if I can get good price
check your email i sent some picture I don't know how to post it here
